Why do Headlights Melt My Max!
Old Mar 11, 2002 | 04:31 PM
MDubya
I thought great ill buy the ice - hyper - headlights off ebay, put em in they melted the housing things and i had to modify,
Next. I buy new housing hook ups from junkyard, install new bluiey headlights and f*** , it happened again!
Now. I cant drive at night . WHY FRED
Old Mar 11, 2002 | 04:36 PM
krzymax's Avatar
Maxima owner since 2000
maybe you're using way too high wattage bulbs?
Old Mar 11, 2002 | 04:42 PM
Kashoggio's Avatar
your regular sockets cant handle the watts that are from after market "hid" bulbs. There for they get too hot and melt. YOu can buy regular watt bulbs ( phillips blue vision is a good choice) or you can buy a 9004 wire harness from Apc for about 45 dollars. Then you will be able to run high watt bulbs and not worry about anything.
Old Mar 11, 2002 | 04:46 PM
Finality's Avatar
Hmm I was under the impression that the wiring can handle PIAA 9004 bulbs?
Old Mar 11, 2002 | 04:49 PM
Ramius83
The stock wiring can handle the PIAA 9004s because they operate at the stock wattage. Other "cheapo" brand lights that offer the "HID" look operate at 85/100 watts. That is why they melt the harness. That extra wattage and heat is too much for the stock wiring/sockets.
Old Mar 11, 2002 | 05:33 PM
MDubya
Thank YOu
yeah i m almost sure both set s were about 80/100 watt.
There we are PIAA is the schizznit.
My questions answered, Ive Found My Site.Ahhhhhhhhh
Old Mar 11, 2002 | 08:06 PM
metallic97gxe's Avatar
Master Will
stay with any bulb of stock wattage of 45 low beam
65 high bean Piaa, Phillips, APC, or Eurolite or whatever
if you use the 80/100 or even more 100/130 bulbs you will need the upgraded harness....
AaronL
Nov 15, 2020 11:52 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
