18 in. tantrums with 2.5 drop
Old Mar 11, 2002 | 08:49 PM
boosted95's Avatar
suggestions or comments on my car with 18 x 7.5 tantrums with h&r springs with some coils cut to make it a 2.5 in. drop?? let me know
Old Mar 11, 2002 | 09:19 PM
tifosiv122's Avatar
Re: 18 in. tantrums with 2.5 drop
Don't cut the coils...bad idea...horrible ride...
Erik
Old Mar 11, 2002 | 09:42 PM
Finality's Avatar
Re: Re: 18 in. tantrums with 2.5 drop
Erik
Is there any cheap way to lower the car/stiffen the suspension so that it doesn't 'roll' or whatever it does.
BTW I'm getting my 18X8 Tantrums on Wednesday
Old Mar 12, 2002 | 05:57 AM
KWheelzSB's Avatar
Erik
ditto.
Old Mar 12, 2002 | 05:58 AM
KWheelzSB's Avatar
Re: Re: Re: 18 in. tantrums with 2.5 drop
Rear-Anti-Sway-Bar (RASB)
Stillen or
Addco
Old Mar 12, 2002 | 06:01 AM
Finality's Avatar
Re: Re: Re: Re: 18 in. tantrums with 2.5 drop
Stillen or
Addco
What about a cheap drop? I was planning to do the RASB next month regardless. But I understand a stiff suspension really helps. I was thinking more in the lines of new shocks?
Old Mar 12, 2002 | 06:57 AM
KWheelzSB's Avatar
Re: Re: Re: Re: Re: 18 in. tantrums with 2.5 drop
Tough to go cheap with a drop. The cheapest you can get away with is replacing just the springs (if your OEM shocks are in decent shape), but if you're not replacing shocks/struts at the same time, you really shouldn't lower more than 1.4" - 1.6" because you'll blow out your OEM struts in no time if you do.
Honestly, lowering isn't something to do "on the cheap." Save up & do it right - otherwise you're gonna have to make some serious compromises.
Old Mar 12, 2002 | 09:25 AM
Str8ridin's Avatar
cutting stock springs is a no-no. cutting sport springs is ok, if you don't cut more than two coils. Anything more than that will cause the spring to lose it's structural integrety and could cause premature spring failure. If you do cut 1 or tow coils, expect a drop in height and ride quality. But the stiffness you will get will definitely tighten up your handling. I've had two coils cut on my eibachs for over 60k miles and no problems so far. It handles like a race car!
jonreidhead
Jan 6, 2016 09:38 AM
maxima-junky
Oct 7, 2015 06:13 PM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
