Help Code 0111
Old Mar 14, 2002 | 08:46 PM
97MaximaGLE's Avatar
Help Code 0111
I did the diagnois and i got the code 0111. I have read a little bit about it and searched the forum but only read what it does. What should i do to fix it? Is this a problem or serious problem to worry about or wreck anything??
Old Mar 14, 2002 | 09:13 PM
jay_x's Avatar
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
I would start with the control valve itself. If you pulled a 0215, see if you can blow air through it. If you cant, try cleaning the valve with wd40.
Old Mar 15, 2002 | 09:06 AM
problems
Where should I look to find this stuff? I think Some more explanation on what to do. Anyone had this code come up before. 0111? If so what did u do to fix it. Does it have anything to do with my intake. I didnt think so
Old Mar 15, 2002 | 10:50 AM
jay_x's Avatar
Did you bother to check the EVAP canister purge volume control solenoid valve to see if its stuck closed? Do you own any of the manuals that can help you help yourself? Is there water in the EVAP canister? If so, drain it and weigh it. If the canister (with the EVAP CVCV attached) weighs more than 4.0 pounds, replace it.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
