rewire my 96 corner lamps????
Old Mar 14, 2002 | 09:08 PM
96maximaguy's Avatar
Hey guys-
Is it possible to rewire my corner lamps so that they stay on the "bright mode" instead of going back and forth when my blinker isn't on. I like the color of the light better when they're brighter. Let me know if it's possible, because I know it is on 97+ max's. Hook me up if ya know how. THANKS!!
Old Mar 14, 2002 | 09:33 PM
rguida's Avatar
Re: rewire my 96 corner lamps????
Originally posted by 96maximaguy
Hey guys-
the way i did it was:
take off your corner lens and look at the harness...if memory serves me right there is a black wire for ground. now, it is as simple as taking the other two wires, splicing them, and crossing them. If you wanna get fancy you can find out which wire actually lights up when you put your corner lights on and and just connect that to the wire that goes to the 22watt part of the bulb, instead of just reversing it. If you have any questions email me as i probabily explained that pretty badly. if you want you can even set that 22watt part of that bulb to blink with your blinkers :P thats fun also!
Old Mar 15, 2002 | 05:13 AM
mzmtg's Avatar
Minister of Silly Walks
There is a MUCH simpler way to do this.
Take out the corner bulb. Cut off one of the little nubs in the base of the bulb. Insert the bulb into the socket backwards. Done.
I used nail clippers to cut the nub off.
Old Mar 15, 2002 | 08:40 AM
rguida's Avatar
hahaha, he is true you can either rewire or cut of one of the nubs, which is easier than what i did. i never have done that and i think i would screw up cutting nubs, so I'll stick to rewiring
Old Mar 15, 2002 | 08:55 AM
cuttin' nubs!
So I wound up cuttin' off the nubs. They work just fine, they stay on the brighter mode. It look so much nicer than that puke green color when it was dim. Thanks for the help guys!
Sir Tilus
Mar 22, 2016 01:49 PM
03VQMAX
Nov 10, 2015 03:39 PM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
conansriver
Sep 16, 2015 12:17 PM
