Noise problem- Ground Control/AGX
Old Mar 17, 2002 | 04:02 PM
Nismo's Avatar
there is a "creeking" noise when you turn the steering wheel that seems to come from the spring on the front passenger side. All bolts and nuts are torqued to spec. any ideas?
Old Mar 17, 2002 | 04:10 PM
jdmmax's Avatar
Re: Noise problem- Ground Control/AGX
yeah i think it is coming from the strut bearing. if you crushed them that will make that noise. happened to me. so what i do now is use grease. everytime you jack the cars up take soe grease put it on top of the strut bering and stick it to the top of the suspension plate taht bolts onto the car. this way you won't have to worry aboutit being miss aligned and crushed. now if you already crushed it then use a S@#$t load of grease problem will go away.
Old Mar 17, 2002 | 04:12 PM
Nismo's Avatar
Re: Re: Noise problem- Ground Control/AGX
thanks. is the strut bearing the little black plastic ring?
Old Mar 17, 2002 | 10:15 PM
jdmmax's Avatar
Re: Re: Re: Noise problem- Ground Control/AGX
yup hehe its a bioch that little damn thing. its made out of freaking plastic. oh well yeah put some grease past it to the top that way when you bring the car back down it will be alighned. now the pain in the *** is when you take your car to get serviced. make sure you tell who ever is working on the car to do the sam eotherwise they might crush your strut bearing.
Old Mar 17, 2002 | 10:31 PM
Nismo's Avatar
Re: Re: Re: Re: Noise problem- Ground Control/AGX
yea I figured that was the problem. When we did the install, we cleaned the dirt off all the components along with the grease.
Old Mar 17, 2002 | 10:54 PM
jdmmax's Avatar
Re: Re: Re: Re: Re: Noise problem- Ground Control/AGX
yup grease it up you should solve that problem
hope fully you didn't crush it.
Old Mar 17, 2002 | 10:55 PM
Nismo's Avatar
Re: Re: Re: Re: Re: Re: Noise problem- Ground Control/AGX
how much would nissan charge for that thing?
Old Mar 17, 2002 | 10:57 PM
krzymax's Avatar
Maxima owner since 2000
i just had the GC/AGX setup in my car tonight and i love it! no noises...yet.
Old Mar 17, 2002 | 11:50 PM
jdmmax's Avatar
Re: Re: Re: Re: Re: Re: Re: Noise problem- Ground Control/AGX
i think they were 15 or so but im not sure it was iether 15- 20 dollars but i forgot that each im not sure though.
Old Mar 17, 2002 | 11:54 PM
Nismo's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Noise problem- Ground Control/AGX
and is there a specific strut bearing lube you need?
Old Mar 18, 2002 | 12:04 AM
jdmmax's Avatar
naw i just went and got a tube of grease from kragen no biggy
i come in like a blue tub they have different grades. i thinnnnk i got the high tempreature grease but as long as it will lube the bering it should be fine.
and every ounce and a while i will go in and clean out all the old grease with a rag and apply new grease. thats it
Old Apr 2, 2002 | 04:03 PM
Dreizehn's Avatar
Courtesy had strut bearings for $21 and change...
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
