shift knob
Old Mar 17, 2002 | 07:28 PM
maximamoose's Avatar
shift ****
i am trying to remove my shift **** on my 5 spd 97 maxima, and i can't get it off. i called a nissan dealership, and they said that you just have to twist it. am i doing something wrong? please reply
Old Mar 17, 2002 | 07:37 PM
Mad Dhan's Avatar
Re: shift ****
its glued plus threaded on there. Do this, take a wet towel and some pliers and twist conter-clockwise. Some on this board even used bubble wrap instaed of a towel. Do a search, you'll see a thread i started asking this same question.
Old Mar 17, 2002 | 08:00 PM
mzmtg's Avatar
Minister of Silly Walks
A strapwrench is the perfect tool for the job.
Old Mar 17, 2002 | 09:27 PM
sil SE's Avatar
a lot of my posts start out like this : "ive said it before and ill say it again"
so having said that, CUT THAT SUCKER OFF! i mean, it ****d me off so bad i jus started cuttin away at it. the glue was SO STUCK i was rippin the leathery stuff with the vice grip.
good luck man
Old Mar 17, 2002 | 10:19 PM
jdmmax's Avatar
good luck man
ahahahahahhaha
started to break things i see. hhheheh ehappens to everyone.
Old Mar 17, 2002 | 10:45 PM
Kevin Wong's Avatar
I'm going to get mine off soon. My STS should be here in a few weeks and I'm very eager to finally get it installed...I've been waiting 4 years(though I just ordered it a week ago). I tried to get the **** off when I first got the car, but the glue won against my hands. I'm going to try the bubble-wrap and pliars / monkeywrench route.
Old Mar 18, 2002 | 02:27 AM
Nismo's Avatar
if you dont care about ruining the ****, you can try drilling a little hole in it and stick a screwdriver through it and turn it.
Old Mar 18, 2002 | 06:09 AM
StygianMax's Avatar
I used a pair of dishwashing gloves & they grip tight! It was definitely a 2-handed job BUT I had no probs whatsoever in getting my stock **** off. A Momo Race Air Leather took its place.
Old Mar 18, 2002 | 06:26 AM
MAXEJA's Avatar
i know what your talking about, i applied a scary amount of pressure to mine ripping some leather off and the thing did not budge. does anyone know if it hurts the actual shifter putting this much pressure on it?
Old Mar 18, 2002 | 12:00 PM
Gary95's Avatar
use a blow dryer
Mine came off without too much of a problem on a very hot day. Maybe you should try blasting it with a blow dryer for a few minutes, to loosen up the glue. Then use a piece of sheet rubber (a drain cover for example) or some other tacky material and twist it off. It'll eventually work...
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
atriuum
Sep 28, 2015 01:19 PM
