Intermittent starting
Old Mar 22, 2002 | 01:30 PM
danimal88
Anyone experience the the problem of intermittent starting? I have purchased a new battery. Have replaced the battery cables. Pulled the starter and had it tested. All this is good. When I turn the key I can hear the relays switching over but starter does not crank. If I wiggle the key while holding in the start position this seems to help and cranks the starter. Does this seem like the ignition switch is bad. Any ideas would be appreciated. Thanks.
Old Mar 22, 2002 | 02:28 PM
SuDZ's Avatar
Re: Intermittent starting
Could be. But also have you done anything like changing the fuel filter? Also if you leave the key in the on position first then start it does it turn over easier?
SuDZ
Old Mar 24, 2002 | 05:55 AM
danimal88
Re: Re: Intermittent starting
SuDZ
When I wiggle the key in the start position I get response. Otherwise nothing.
AaronL
Nov 15, 2020 11:52 AM
Smackasmith
Feb 1, 2016 12:40 AM
mikeg75
Nov 30, 2015 05:12 PM
RWCreative
Sep 21, 2015 11:01 AM
johnaschon
Sep 14, 2015 04:29 PM
