Will a Bad starter Trip a Check Engine Light?
Old Mar 25, 2002 | 11:51 AM
Gumby510's Avatar
Took my car in and I have the noturious starter grind most high milage 95 starters get. I tried to start this morning and it was turning over and was just hard to start with the motor sputtering. Then check engine light came on. I took it to nissan and they said it was the starter. Does a bad starter trip the engine light?
Old Mar 25, 2002 | 12:19 PM
Dreizehn's Avatar
Mine didn't.
Old Mar 25, 2002 | 12:23 PM
sparkymax96's Avatar
Yes it can. Did it on my 95 right before I had it changed out.
Old Mar 25, 2002 | 02:38 PM
mango95se's Avatar
Mine didn't either. The starter just decided to quit without any warning..
Originally posted by MadMax95
Mine didn't.
Old Mar 25, 2002 | 02:58 PM
Jeff92se's Avatar
I'm needing a caw
Did you run the ecu diagnostic to find out what code the ecu read?
Old Mar 25, 2002 | 03:12 PM
jay_x's Avatar
Two different problems. From my experience, the more common starter problem is the development of dead spots (turn the key, no cranking).
It sounds like Gumby510 had a problem where the starter was cranking, but not in a standard pattern and disrupted the normal rhythm of pulses from the crankshaft positioning sensor. See DTC 0407
Old Mar 25, 2002 | 03:26 PM
Jay_x that is exactly what was happening to my Max. New starter fixed it right up.
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
