Alignment Q: do different wheels/tires matter?
Old Mar 26, 2002 | 01:34 PM
KWheelzSB's Avatar
Ok,
I need to get an alignment since I lowered my car. I have the OEM 15" alloys on the car now with worn-out 225/60 15's. I have an almost brand-spankin' new set of 17" Katana K6's w/ 235/45-17's ready to replace them. I've waxed them and they're in flawless shape, so I'm thinking. . .I'd rather have the mechanic man-handle the old OEM alloys (instead of my shiny new wheels) when the alignment gets done. The overall diameter of these two different wheel/tire combos is pretty much the same (allowing for the diff. depths of the worn-out vs. new treads) and both wheels have a +40mm offset.
My question:
Is it OK to get the alignment done with the 15"s on the car and afterwards - swap the 17"s on myself? -or is there a specific reason why I should get the alignment done with my 17"s on there? I've seen that recommended, but I don't understand why. Would the alignment correction be any different on the same car with the only different variable being the wheels/tires? I can't see how, if the O.A.D. & offset remain the same, but maybe I'm missing something(?) Anyone who has technical knowledge on this, please sound off.
Thanks in advance.
Old Mar 26, 2002 | 02:52 PM
SuDZ's Avatar
I would suggest putting the new rims on there because if the offset or camber is different on the new rims it mind make you wind up having to get an aligment anyhow. Plus if your redoing everything might as well have it all on there to get everything matched together perfect.
SuDZ
Old Mar 26, 2002 | 11:23 PM
KWheelzSB's Avatar
SuDZ
Offset of my 17"s is same (+40mm) as OEM 15"s. How would suspension camber be affected differently between wheels of same OAD & offset? I'm honestly confused. Anyone? Thanks.
Old Mar 27, 2002 | 07:29 AM
JAY25's Avatar
your putting more width on the road that is hes trying to tell you, sideways not up and down, install your new wheels and take it to the alignment shop, is worth your while, and these are new tires as well.
Old Mar 27, 2002 | 07:36 AM
1MAX2NV's Avatar
I always use my 15" hubcaps for the alignment. They will scratch up the lip area during alignment. They need to hook these metal points up againest the lip of the rims.
Old Mar 27, 2002 | 11:34 AM
KWheelzSB's Avatar
Thanks, guys. Appreciate the responses.
mkaresh
Mar 12, 2018 06:48 PM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ivorton23
Sep 26, 2015 09:47 AM
