Drive Train Jolt
Drive Train Jolt
Do any of you 5spd guys experience major jolts every time you release the gas pedal and then reapply (especially in 3rd gear). Someone mentioned it was just the maxima drive train but now its starting to get really annoying. The car is so smooth until you take your foot off the gas and then reapply the gas pedal. I've tried everything from keeping the rev's really low to keeping them really high.
Any comments
DT
Any comments
DT
Does the jolt stop immeditely, or does the entire car have oscillations for a few seconds or so after you nail the gas? If the latter, then you probbly have a busted motor mount. You can bust a motor mount at 150 miles, or 150,000 it doesnt really matter. You wont really feel much more vibration at idle with a blown mount, but you will feel more clutch chatter. If your car is not experiencing these problems, then its just the nature of the car. Alot of slop and flop in the drivetrain. You can cut down some of it by polyurethaning the motor mounts.
Originally posted by Toffy
No its a very abrupt jerk. Maybe Im just not used to the Maxima. I've driven Hondas in the past and have never noticed it. It seems as soon as you take your foot off the gas the car decelerates (as if you are in too high a gear or your parking break is stuck) Then when you reapply the gas it feels like the car has way to much power (i.e the gear is too low)....very weird but perhaps its a Maxima chararcteristic. I can't believe any ex honda owners have made the comparison in the forum before.
My 2 cents.
Mark
I have the same problem but...
mine didn't start until AFTER I got it back from the dealership for a bad differential bearing repair. My guess is they didn't tighten things up enough in the drivetrain causing the jolt that you described. Every time I gun it after taking my foot off the gas at around 3K it feels like I've been rear ended by an 18 wheeler.
Motor mounts
Since clutch chatter was mentioned as a culprit of worn motor mounts, is there a better mount out there other than OEM? Also, I have a late '99 5spd that seems to have the EXACT symptoms described for the 5th gen. Fuel Shutoff TSB. I think this might have contributed to my mounts going bad, if they are. Could that TSB apply to me?
Just wondering if any of the posters to this thread had any resolution to this problem. I have a 98 SE w/ 70K that has this problem. It's most noticeable in 1st and 2nd gears. The car has been doing it since I got it about 9 months ago. I didn’t think it was too bad, but I drove a friend’s 99 GXE 5 speed last week, and the difference was amazing. The on/off throttle transition felt like an automatic’s.
I thought it was just typical of engine breaking as well. I've driven a number of manuals (including two hondas, to respond to the original dated post) and all needed to be feathered softly off and on the gas, especially in lower gears. None of the cars were new cars, so I'm not sure about mounts. My way around this a lot of the time (read: when I'm lazy and don't feel like feathering) is to drop to neutral, and double-clutch when gas is needed later on. Of course, this is better in some situations than others.
Really, I just thought this was something that happened in all manual transmission cars. Now if only I could be sure that my intermittent clutch issues were due to mounts...(THAT never happened in the hondas. Casualty of torque?)
Originally posted by blizz20oma
I thought it was just typical of engine breaking as well. I've driven a number of manuals...
For me, this is not a shifting problem. With the clutch fully engaged in 1st or 2nd, the car bucks during an on/off/on throttle transition.
With the hondas I used to drive I figured it was a symptom of short gearing.
Mar 12, 2020 12:06 AM
