I've cleaned my TB, I've replaced my knock sensor...
I've reset my computer...
Yet, everytime I start up my car, the RPMs run as high as 1500...
And after its warmed up, in Park, with NO accessories running, the
lowest I'll get to 900-950 RPMS....WTF?
Shouldn't my car idle around 700 in Park after warm?
For those in cold weather, what RPM range does your Max start at?
Should I touch my idle adjustment screw????
thoughts???
thanks!
FLO_BOY
thoughts???
thanks!
FLO_BOY
Re: I've cleaned my TB, I've replaced my knock sensor...
thoughts???
thanks!
FLO_BOY
thoughts???
thanks!
FLO_BOY
SuDZ
Re: Re: I've cleaned my TB, I've replaced my knock sensor...
Originally posted by SuDZ
Has it always done this or just strted recently? Cause I if it has always done it maybe the line that connects to the throttle ot open up the throlle body? Just a thought.
SuDZ
SuDZ
and this is when the RPMs started to go higher...
From posts on the .org, most people experienced this, but, had this
issue go away as the car's computer "re-learned" how to run itself.
I figured this would go away after the KS replacement...but, no luck.
3 weeks is awfully long to relearn (esp. after so many computer resets!)
-FLO_BOY
RPMS at 1500 in Southern California
Well if you have resetted the ECU then check it for error codes. See if anything is reported other than 0505. Then check neat the throttle body, is everything tight and connected right?
SuDZ
SuDZ
After my TB cleaning, my RPM's were high at normal idling, but I just turned my idle adjustment screw down one full turn. Now it idles where it supposed to be.
CorollaULEV
30
Aug 9, 2021 08:11 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
