antenna
Old Nov 22, 2000 | 09:31 PM
Jimp
I have an aftermarket CD player, and also an amp and 2 sub's in my Max. Does anyone know how to wire the antenna, so you can let it down when the CD is playing but also have it come up when ever you have the radio on? I want the sub's to always stay on. Just want to be able to controll the antenna?
Old Nov 22, 2000 | 09:36 PM
OzMaToz
Are you using the antenna wire for the remote turn-on for your amps? All you need to do is run an extra wire off of the switched power lead wire from your head unit. (Most come with two, one is constant on with little draw to remember settings). Use the switched lead as your amp turn on signal because that will have the amps turn on anytime you use the system, and use the antenna switch strictly for the radio.
Old Nov 22, 2000 | 09:52 PM
Victim64's Avatar
Yeah, it depends on your CD player, but it should have a remote wire that you can run to your amp and your power ant. If it just has one split it for both. Anyway at least you have an antenna, I ripped mine off at the car wash. I got the hose rapped around it and I didn't know. Oh-well, **** happens.
MikesChevelle
Nov 23, 2024 11:17 AM
chisam14
Nov 6, 2018 08:56 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
98nismomax
Aug 13, 2015 12:44 PM
