Reverse works 50% of the time
OK, I have a '95 SE, auto (I know, I wish I had a 5spd).. When I shift to reverse, only about half the time will it catch like it is supposed to. The other times, the enger rpm will go to about 2000-2500rpm before the gear starts to "catch" like a manual would, and then it sort of jerks in reverse. You can tell it isn't good for the car, so I know to shift back to drive, roll a foot, and then stop, go back to reverse and hope it works. I talked to a guy at a shop about it, and without looking at it, he told me it could be a worn out grommet to "wiggle" my gear shift and see if it would catch - that doesnt do anything. Do you all have any ideas before I take it in?
Ieea #2) Your transmission is approaching the point of needing a rebuild. Unless this has been done recently, replace the fluid. New ATF is clean and loaded with detergents. This may "buy time" before that expensive rebuild must be done.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
