Dome light doesnt work / Climate control lights
Old Nov 23, 2000 | 12:13 PM
hlh0501's Avatar
#1. My internal light doesn't work, and I checked the fuse and the light bulb. Both are fine - what should I do next?
#2. I have read some posts about the light behind the climate controls temp. up/down thing in my 95 max, saying that it cannot be replaced. The 1st owner of my car said she took it to our nissan dealer and they said it couldn't be replaced. I just wanted to check before I gave up on it, you all haven't found any like trick or whatever to getting a new light behind it?
Old Nov 24, 2000 | 07:13 AM
kest
Are you talking about the electronic climate control? If so, I got all of my lights out. They are very tiny and they sit in a little plastic connector. There are four of them if I remember correctly. It's not hard to do. My dealer told me that the lights run about $7 EACH.
Old Nov 25, 2000 | 11:27 AM
sferna1
you had all your out too?? all mine are out except for the actual lcd display. that and the light that is behind the cigarette lighter and ashtray. if these are all replacable, do you think you could find out the bulb numbers? and how did you get behind the climate control to change the bulbs.
thanks
MaXeD OuT
96 SE Max 5spd
Old Nov 26, 2000 | 05:36 PM
mo'max's Avatar
Climate Lights
If you have the 95 with the manual climate controls I've written a set of instructions on how to replace these bulbs. Which do you have?
Old Nov 27, 2000 | 09:46 AM
straight six's Avatar
mo,max,
I would be interested in those instructions. I installed a new head unit last week and just noticed that my red hazard,
rear defrost, and all climate control position lights are now out. I might have missed a connector when putting the dash back together but they do not work now. A/C still lights and temperature select still lights also but the above mentioned items do not light up.
Old Nov 27, 2000 | 11:31 AM
Eric L.'s Avatar
Re: Climate Lights
I would like to see those instructions. Would you please post the link, or email me the instructions? My email is ehylee@ucdavis.edu
My rear defogger switch is not lit anymore. The orange light comes on, but the little symbol on the switch does not turn on at night.
Old Nov 27, 2000 | 11:57 AM
To sferna1, hlh0501
I found the instructions by searching the forum archives. The thread is located here and the instructions here as a word document. Props to Adidas_Boy for the great instructions, I'm going to fix my dash lights after work today.
Peace,
Old Nov 27, 2000 | 02:18 PM
sferna1
to straight six,
thanks for the link man!
MaXeD OuT
96 SE Max 5spd
Old Nov 27, 2000 | 05:06 PM
Cutler's Avatar
Electronic CLimate Control lights out
I have a 95 SE and it has the Automatic Climate control system and tonight all the lights went out around the LCD read out, I can't tell what controls what, I have to hunt for the buttons but everything functions correctly. Also My hazard light switch is out. Has anyone successfully fixed this and if so please advise me in how to do it. Thanks in Advance and for helping me cure this problem.
Jason
Old Nov 27, 2000 | 06:25 PM
CFC's Avatar
CFC
I have replaced my hazard and defrost switch bulbs ...
they are simply 12V mini lamps. You can get a pack from Radio Shack for like $2.50 or $3.00. The box has 2 bulbs. The part number is 72119 and Box# 272-1092c. Let me know if you need some more help.
Old Nov 30, 2000 | 05:16 PM
kest
If you still need the part number for the automatic climate control bulbs, here it is. They usually go for $8.50 but I told the dealer that another nissan dealer quoted me $3.50. That's the price I got. Hope this helps.
part# 28529-0p000
Kest
carguy96
20
Feb 6, 2021 06:21 AM
dr3am
25
Oct 22, 2015 08:53 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
