Check Engine Went off - do codes get erased
Old Apr 7, 2002 | 06:15 PM
BobMax's Avatar
My '99 had a check engine light on. Since it is still under warranty,
I let it stay that way for the dealer to check it at an appointment
(tomorrow). The light has now gone off on it's own, after about
7 days and probably 30 engine starts. Will the error codes still be
in the computer ? Or did they reset when it shut the
light off ?
I really don't want to waste the time or money at the stealer if
the codes are no longer stored. I'm sure that they'll charge me to
poke around for an hour, then declare "nothing found. I'll spend
over an hour dropping the car off with drive time, and another hour picking it up. So, if the codes are gone, I'd prefer to skip the
visit to the stealer.
Thanks for any info,
Bob
Old Apr 7, 2002 | 06:44 PM
clee130's Avatar
If the check engine light disappeared, then I wouldn't worry about it. If it comes back on, then do an ECU check yourself. It's covered in the "ECU fault code diagnosis" thread up top.
Old Apr 7, 2002 | 10:04 PM
MIXXMAX's Avatar
It wouldn't hurt just to reset it, or just check to see if you have the 0505 code.
Old Apr 8, 2002 | 11:28 AM
sbmax95's Avatar
That is a good thing. A buddy of mine put his intake off of his 300ztt and put it on my car, thus causing the engine light to come on. Thankfully his dad works a nissan parts garage. He told me that after about 100 starts the ecu will reset itself. I hope this helps you!
Old Apr 8, 2002 | 11:44 AM
SuDZ's Avatar
What it does more so is if it no longer detects a problem for X amount of times in a row the car was started it will turn itself off. Sometimes on things like an intake it reads it as too much air coming in and throws a CEL. If it is gone it means the problem has not happened in a while.
SuDZ
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
