P/S flush
Old Apr 10, 2002 | 04:19 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
P/S flush
I was told by my dealer that I should do a BG Power Steering system flush soon.
2 ?'s...
1) Has anyone tried/done it?
2) Is there better performance, steering-wise from the service?
Old Apr 11, 2002 | 07:59 AM
maximus75's Avatar
Re: P/S flush
2 ?'s...
Unless your having a prob with your p/s don't bother. If your that concered you can drain the resevior and refill it your self. BG prob suckered them into buying that machine and now they have to pay it off. Also check your maintenance schedule. I don't think it sais anything agout flushing the p/s fluid.
Old Apr 11, 2002 | 08:29 AM
xHypex's Avatar
There's no scheduled maintenece of PS fluid, but depending on how many miles your car has it might be worth it to change it. I'm going to do a drain and fill this summer because I was getting a squeek from my power steering this winter. I also noticed some fluid on the underbody of my car and on the boot on the PS rack, but none on the ground Hopefully I have a really slow leak or something because I don't want to be replacing the rack.
-hype
Old Apr 11, 2002 | 09:35 AM
Chunger's Avatar
My other car is a Hybrid
Go ahead and change it yourself...
The PS fluid "cooler" is in front of the A/C heat exchanger... Just take off the bottom hose and the PS fluid should drain out... If you want you could quickly start the car and turn the wheel left/right. to pump the rest out... do this quickly cuz you can burn out the pump. Reattach the hose then refill with Mobile 1 Dexron ATF, restart, turn wheel left/right, refill to the appropriate level.
Dirty PS fluid can mess up (wear) the seals in you PS Pump.
Old Apr 11, 2002 | 09:54 AM
-hype
I have almost 71,000 miles, so would it be time then to change the P/S fluid??
sctludwig
Sep 1, 2022 01:32 PM
user 11122324
42
Jul 18, 2022 03:35 PM
rbuswell
Nov 17, 2016 04:54 AM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
