just bought these healight bulbs....
Old Apr 13, 2002 | 08:12 AM
EN_Maxima's Avatar
I just bought these headlight bulbs off ebay. http://cgi.ebay.com/ebaymotors/ws/eb...3&r=0&t=0#BID1 Does anyone else have these? or an opinion on them? they are 100w/80w so i don't think they will burn the wiriing harness. I had other ones for about a month and they were fine.
-Ian
Old Apr 13, 2002 | 08:40 AM
clee130's Avatar
Yes they will burn the harness.
Stock wattage is 55w/65w.
Personally, I think these kind of bulbs are crap.
Get a pair of Philips BlueVisions instead.
Old Apr 13, 2002 | 09:48 AM
Gotrice4's Avatar
Also, don't believe that those bulbs "meet DOT regulations" overwatt bulbs never do, especially, Japanese, Chinese, Taiwanese bulbs never do...
Old Apr 13, 2002 | 10:02 AM
EN_Maxima's Avatar
Well, the entire reason I stayd away from the Philips brand of bulb was because of the blueish tint. These bulbs only have a slight one. Also, I guess as long as they say they are DOT apporved on the box the cop really can't give me a ticket.
-Ian
Old Apr 13, 2002 | 10:29 AM
Dhruv's Avatar
what about Nokya Artic Whites? will they fry the harness?
Old Apr 13, 2002 | 10:32 AM
thezcarguy's Avatar
I have 80/100 watt bulbs and in time they WILL burn the harness. It took mine about 2 years to burn but they did. So i got new ones and all is good. I dont think a new harness every 2 years is too bad.. I like the look and the light output of the higher wattage bulbs.
John.
Old Apr 13, 2002 | 02:23 PM
Gotrice4's Avatar
-Ian
quite the contrary, they can give you a ticket, even if the box says "DOT Approved" First, there is a problem with the terminology they use. The Department of Transportation, does not "approve" OEM or Aftermarket products... they set standards and companies are required(or should) follow these regulations...DOT compliant or "Meets DOT or SAE standards" is more correct. Usually companies put that on box. When "DOT Approved" shows up on packaging, it usually means that the company does not know the actual standards and regulations. So, you can get a ticket for "DOT Approved" lights....
Old Apr 13, 2002 | 03:34 PM
spiff56747's Avatar
-Ian
Philips Bluevision are NOT white or blue in any way whatsoever.. They're yellow as all hell.... Maybe slightly more white than stock, but still yellow.. If you want good visibility, by all means get Philips.. If you want hyperwhites, look elsewhere, like Naxos or Nokyas.
Old Apr 13, 2002 | 07:43 PM
peteymax99's Avatar
Philips blue are the same wattage as oem?
Old Jun 12, 2002 | 07:23 PM
iregula's Avatar
nokya is rice bad
Old Jun 12, 2002 | 07:40 PM
Jamsan's Avatar
my friend got "tucans" (sp?) headlights and h3 fogs and they look really sweet...
Old Jun 12, 2002 | 09:21 PM
kwamdoo74's Avatar
Carpe Diem....
I would even go with the Eurolie xenon fusion bulbs as well, nice and blue with out the strain on your harness 65/45, just like stock........
Old Jun 12, 2002 | 09:28 PM
co_maxima98's Avatar
Has anybody ever had a cop ever actually pull them over and ticket them for having over watt bulbs? Come on... how would they check the wattage? Actually take them out of your car? Maybe the cops in my area just don't really care much, because I've never heard of anybody having a problem.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
