On my second y pipe....still messed up
I just put my Y pipe on today. This 1 is brand new and it still does the samething. It rattles the whole car when ideling and when I put it in reverse. What should I do? Suggestions? It's a cattman by the way.
Re: On my second y pipe....still messed up
did you try replacing the rubber hangers for the piping that worked for me i was getting the same thing.
I had the same problem after I put on my WSP y-pipe. I could not figure out the problem so I brought it to a shop, and they fixed it for $15 (everything is a lot easier if you have a lift). It was one of the brackets on the exhaust, I think the one that holds it in place at the y-pipe-cat connection, that took care of it though.
i had the same problem but now SOLVED...
i had a HUGE BIG!!!!!!!!!!!!!!!!!!!!!! post about this...
but i will be nice and won't say "SEARCH YOU NEWBIES"
ok
here we go
you ready?
you sure?
aite..
cool
bye
jk..
-Contact cattman or whatever company you bought it from and say it doesn't match. Cattman(mine) will fix it and send it back to you.
but for me it came back and it was still touching the k member of the car... k-member(black bar between the front wheels)..
the y pipe SHOULD NOT be touching anyhing.
-Find a shop where they get WELD The damn pipe.
WELD- Heat the damn pipe up and HAMMER THE SHIET!! (only the parts that are touching the car)
-Put it on, check if it touches anything, if it is, weld that shiet too.
-make sure nothing is touching and drive.
-pay the mechenic for his good service and enjoy the gain of hp.
no need to get a different one... too much hassle.
-Sexima, you superhelper
ok
here we go
you ready?
you sure?
aite..
cool
bye
jk..
litch
123
Jan 4, 2024 07:01 PM
