Help with H&R spring install!!!
Old Apr 16, 2002 | 07:55 PM
rmb's Avatar
rmb
I'm installing the front H&R's with AGX's now on a 98 SE 5spd.
Which way is up for the spring? Both ways seem to seat ok. One end of the H&R spring is a liiittttllle farther away from the previous coil.... but otherwise identical.
That would lead me to believe that the printing should go upside down since the stock spring
Is your H&R printing on the spring rightside up or upside down?
And before I get to the back... what about there?
-RMB
Old Apr 16, 2002 | 08:05 PM
iwannabmw's Avatar
Re: Help with H&R spring install!!!
-RMB
I put mine in with the printing right side up
Old Apr 16, 2002 | 11:00 PM
spiff56747's Avatar
I dunno about H&R's, but for my B+G's, I put them in so the closely spaced coils are on the top. And the B+G lettering is right side up.. I think that's right, because the stock springs also had the closely spaced coils on the top.
Old Apr 16, 2002 | 11:54 PM
rmb's Avatar
rmb
Thanks...
The H&R's in the front don't have any closely stacked coils... I'm going to try letters up, it seems to fit ok...
-RMB
Old Apr 17, 2002 | 12:12 AM
CHI99Limited's Avatar
Thanks...
-RMB
I did mine Fri and put them on with the lettering rightside up and everything is fine now.
Old Apr 17, 2002 | 12:16 AM
sbslacker's Avatar
Re: Re: Help with H&R spring install!!!
ditto...
Old Apr 17, 2002 | 04:38 AM
BlancMax's Avatar
I think I read in another post that the lettering should be right side up. I would do a search to confirm it though.
Old Apr 17, 2002 | 06:53 AM
JAY25's Avatar
I installed my rear Konis about 6 or 7 months ago and the spring would not sit correct on the perch which looks like a cup. I read someone posted that the closer coils go on top, so whomever said that is correct. At first the spring would not fit in the perch so I placed the perch upside down which I did not know I was placing the spring upside down. I later read the directions again just to find out that I did it wrong, so this Sat I fixed the perch that it sits on and found also found out that the spring, I installed upside down, thats why it did not fit in the Koni cup perch. But now is a perfect snug fit.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
