Lowering my MAX
Old Apr 17, 2002 | 07:07 AM
blakkrob's Avatar
Lowering my MAX
What's the lowest you guys have went without a camber kit. Will 1.5 or 1.7 be ok with 18 inch rims. I am considering coilovers. What are the ranges they can adjust to?
Old Apr 17, 2002 | 07:10 AM
BRIGBOY's Avatar
No need for camber...
...2" or lower you'll need a kit. Coilovers are usually 1-3" I think. Maybe 3.5".
Old Apr 17, 2002 | 07:11 AM
tifosiv122's Avatar
Re: Lowering my MAX
Most coils will drop down 3 or so. I have about a 1 or 1.5 without camber problems. I have Ground Control Coils and I will drop them more now that I am putting on my 17" rims back on.
Erik
Old Apr 17, 2002 | 07:25 AM
blakkrob's Avatar
Re: Re: Lowering my MAX
You have the coil overs ? If so how much did they hit ya for?
Erik
Old Apr 17, 2002 | 07:57 AM
JAY25's Avatar
Re: Lowering my MAX
I myself have 18 with 245/40 and I am at like 2.1 no camber kit nor have I aligned ever since I cut my front coils.
Old Apr 17, 2002 | 09:32 AM
tifosiv122's Avatar
Re: Re: Re: Lowering my MAX
I paid $400 for the coils, and $400 for the AGX's and $200 to put them all in.
(Note: I had the AGX's when they first came out...so I paid more then I should have. The coils I needed right away..again price is higher)
Erik
Old May 20, 2002 | 01:57 PM
BippuBenji's Avatar
Since you have 245's, no camber kit, and no alignment, are your tires wearing unevenly? I have 245's, Intrax springs, and I got an alignment awhile ago, but my inner sides of the front tires are wearing a lot faster than the outside. I'm thinking of going to 235's or maybe even 225's and sacrifice ride comfort if I come to find out that the 245's are going to wear out faster than the others.
Old May 20, 2002 | 05:50 PM
JAY25's Avatar
No wearing out on the inside. I only had two alignments ever since I lowered my car. I cut a coil and lowered it even lower and no camber kit. I did however installed one and it made a loud snapping noise and the bolt came out of place. To correct the camber problem what I did was loosen both bolts that hold the front shocks located right above the brakes, pulled on it very hard and tighten the 17MM bolt. Thats is all I did. I dont have inner wear at all.
imported_Nismo_max
Feb 17, 2016 03:39 AM
Starrider
Dec 18, 2015 04:43 AM
Violator
Sep 9, 2015 10:14 AM
