clutch or transmission problem?
Old Apr 17, 2002 | 10:51 PM
kyllr's Avatar
I have a 1995 NIssan Maxima SE and im have a strange problem. I'm not sure what the problem is but when im driving sometimes in first gear when i take off my car jerks as if i dont know how to dive stick. It does it only sometimes though. Im suspecting a bad cluctg and ideas?
Old Apr 18, 2002 | 01:31 AM
justmax's Avatar
Re: clutch or transmission problem?
Does it do it *only* when the car is cold (within a couple minutes of starting)? If so, you have clutch chatter. I have the same thing on my '99 with 32K miles. I noticed it within the first 10K miles actually.
I know some folks have bought ACT clutches and they reported that the chatter was gone.
Old Apr 18, 2002 | 07:56 AM
kyllr's Avatar
Re: Re: clutch or transmission problem?
iT DOES IT A NO GIVEN TIME SOMETIMES ILL BE DRIVING FINE THEN ALL OF A UDDEN WHEN IM AT A STOP SIGN OR RED LIGHT IT WILL DO IT.
Old Apr 18, 2002 | 09:17 AM
dwapenyi's Avatar
WHY YELL!
Anyway, it could be the engine not running a smoothly. Try a basic tuneup, change oil, air filter, feul filter. The car runs much smoother just after an oil change etc.
DW
Old Apr 18, 2002 | 10:22 AM
GarthG's Avatar
It is normal, don't worry about it. . . If you search for this topic you will see that most 5-spd owner have this problem. It normally happens at slow speeds and in 1st gear and I don't know if anyone has ever really come up with a reason for it.
Old Apr 19, 2002 | 03:03 PM
98se5spd's Avatar
My car does it too...mostly when it's cold and damp...but it does it other times also...only in 1st and 2nd gear. Sometimes the whole car vibrates and it is impossible to shift smoothly..other times it smooth as silk. It'll sometimes vibrate, though not as much, downshifting to 4th or 3rd. After reading all the posts on clutch chatter, I've concluded that it is something that I am just going to have to live with...It's just a little embarrasing when you're on a date..
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
The Wizard
24
Oct 1, 2015 08:47 PM
