Greasing alternator bearings
Old Apr 19, 2002 | 10:49 AM
jayanth's Avatar
Has anybody done this?Just wondering as a bad bearing attributes to 90% of alternator failures.Can/should the alternator bearings be greased??
Old Apr 19, 2002 | 12:47 PM
njmaxseltd's Avatar
You can't grease them but you can replace them. Bearings have a number stamped on them, call a local bearing supply house. There cheap too, like 12 - 20 bucks each. While your at it, replace the brushes and clean the armature with emery cloth. Nissan probably sells a brush kit for it or you can get them at any rebuilding shop.
Total cost to rebuild your alternator, provided all your electronics are good should be around 50 bucks.
Old Apr 19, 2002 | 03:15 PM
rmb's Avatar
rmb
Re: Greasing alternator bearings
Sealed bearing... no grease.
Press it out if you can and replace. It's the only fix...
-RMB
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
