My back passenger floor is soaked..
Old Apr 18, 2002 | 04:08 PM
Chris96SE's Avatar
The floor on the back pasenger side of my car is completely soaked, it looks like someone took a hose and left it running in there for a few minutes.. Anyone know what the problem might be?
Old Apr 18, 2002 | 04:28 PM
kmax's Avatar
I'll guess the rear window is leaking. Check the trunk for signs of water. Other than that wait until it drys and try hoseing down a window at a time. Also check the door seals and sunroof (if you have one).
Old Apr 18, 2002 | 05:02 PM
gtr_rider's Avatar
192.168.1.1
I had this happen one time, couldnt figure it out, its gonna be wet for a week or so, or you can dry vac it.
Old Apr 18, 2002 | 05:10 PM
BRIGBOY's Avatar
Was your window down anytime recently when you left the car alone...
..I peed in someones open window once...but they deserved it
Old Apr 19, 2002 | 12:53 AM
Chris96SE's Avatar
ok
There are no water spots anywhere on the leather seats or anything, so I don't think it's the sunroof, or the window..
Old Apr 19, 2002 | 01:28 AM
Nismo's Avatar
rent a carpet shampoo cleaner vaccume and suck up the water.
Old Apr 19, 2002 | 04:28 AM
BRIGBOY's Avatar
Your headliner is totally clean too?
After the car wash one day I notice a bit of water dripping from the headliner in the back, I needed a new seal around the top corner of the rear window(not door windows).
Old Apr 19, 2002 | 06:47 AM
maximus75's Avatar
If you have a sunroof the drains might be clogged. There should be 4 of them. One in each corner. You can see them when the sunroof is open. there are tubes that run down the a and c pillars to drain the water at each corner of the car. You can pour water in them to make sure there draininmg properly.
Old Apr 19, 2002 | 06:50 AM
paul-e's Avatar
this haoppened to me in my old car and i couldnt figure out what haoppened so i cleaned it up and all and couple days later it came back and this went on and on and the car smelled so bad LOL
Old Apr 19, 2002 | 09:28 AM
kvzeyde's Avatar
check wheelwell
The water could be coming from below if you have a rusted or damaged area at the rear wheelwell. When you drive through standing water, the tires spray the water against the wheelwell. A very small hole will allow a lot of water to get in when you are driving in the rain. Good luck finding the source of the water and let us know when you figure it out.
Old Apr 23, 2002 | 11:36 PM
Chris96SE's Avatar
Thanks a lot for everyone who helped. I haven't had any time to even check anything because I've been so busy, but I'll try everything mentioned when I get some free time.
Thanks again
-Chris
JRod28
Dec 29, 2023 09:56 PM
max1029
Aug 26, 2015 09:51 AM
george__
Aug 18, 2015 07:06 PM
erniel
Aug 8, 2015 09:32 AM
