To All With H&R Setup..Look inside...
Old Apr 18, 2002 | 04:46 PM
PejMax97SE's Avatar
I recently got my 97 max and its in dying need of being lowered. I know the H&R setup with agx is the closest i can get to stock but this is the thing, i've heard the H&R's dont give the car a lowered look. Since the drop is only 1.5" front and 1.3" rear, is the car still going to look like a 4x4 or what? Can all of you who have H&R's please post some pics of ur cars here so i can see how it looks. Thanks in advance.
P.S. - dont tell me to use the search function! , already did and didnt find any good pics of max's with H&R setup.
Old Apr 18, 2002 | 04:55 PM
BRIGBOY's Avatar
I searched an found plenty...
...but your car will look plenty dropped with H&R's. I have eibachs and they are the same drop, check my webpage.
Old Apr 18, 2002 | 05:14 PM
AndyXXL's Avatar
Re: To All With H&R Setup..Look inside...
Email me for pics.
Old Apr 18, 2002 | 05:27 PM
araffio's Avatar
I have H&Rs and my car definitely looks dropped. Not slammed, but much lower than stock, not even close to 4x4. I may be switching to Eibachs for the stiffer ride. H&Rs handle great and ride close to stock, but I want more performance and a harsher ride. Call me crazy...
Old Apr 18, 2002 | 05:52 PM
Lime's Avatar
http://www.nemaxima.net/lime/limemax12801_1.jpg
http://www.nemaxima.net/lime/limemax12801_2.jpg
http://www.nemaxima.net/lime/limemax12801_3.jpg
http://www.nemaxima.net/lime/limemax12801_4.jpg
Old Apr 18, 2002 | 06:05 PM
AndyXXL's Avatar
I think my car used to sit a little lower that yours, Erica.
I'm back to 4x4 now
Old Apr 18, 2002 | 06:56 PM
PejMax97SE's Avatar
Looks pretty good so far, Post some more pics guys...
Old Apr 18, 2002 | 07:21 PM
ny96max's Avatar
CHECK SIG PIC
This is how H&R should look, but they dont unless they are cut one coil all around for a 100% even drop
2 finger gap all around couldnt be more perfect!
Ant
Old Apr 18, 2002 | 08:40 PM
DCmax's Avatar
Check my page.
Old Apr 18, 2002 | 08:53 PM
Kevin's Avatar
seeing that pics makes me wish I had gotten a black maxima instead of a white one. nice...
Old Apr 18, 2002 | 09:16 PM
Nismo98's Avatar
Get Intrax, I think they give you the best drop.
Andrei
Old Apr 18, 2002 | 09:45 PM
spiff56747's Avatar
that maxima is quite possibly the cleanest maxima i've ever seen.. the wheels are spotless!
Old Apr 18, 2002 | 09:56 PM
Max4U's Avatar
H&R's, check out the sig.
Old Apr 19, 2002 | 05:27 AM
Kevin's Avatar
Originally posted by ny96max
CHECK SIG PIC
Ant
IS that stillen kit on your car? looks good.
Old Apr 19, 2002 | 05:32 AM
deezo's Avatar
Her car is dark green.
Old Apr 19, 2002 | 05:36 AM
Kevin's Avatar
Still...dark is better the white for maxaim IMO..
Old Apr 19, 2002 | 05:41 AM
njmaxseltd's Avatar
H&R's Installed
Stock
Old Apr 19, 2002 | 06:00 AM
caneyebus's Avatar
you could have looked at the page that had pics of lowred cars with different applications..
Old Apr 19, 2002 | 06:28 AM
Lime's Avatar
thanks
This picture was taken not TOO long after the car was dropped...it's a little bit lower now that it has settled. The drop is not huge, but it looks NICE now, no more 4x4.
The car is dark green, yes, Deezo has seen it in person more than once when he graced CT with his mighty presence! DEEZO POWER!
The wheels have a few nicks and scratches up close...and the paint is ruined...but you can't tell in indirect light. I love the color, and am hoping to get enough $ to get the exterior repainted.
Old Apr 19, 2002 | 06:32 AM
190hpKiLLA's Avatar
Granny Driven
This is sprints 2 inch drop set up in case your intrested.
http://a2.cpimg.com/image/3C/86/9019...-02000153-.jpg
Old Apr 19, 2002 | 08:22 AM
Lime's Avatar
as discussed in other threads: warrantee on aftermarket struts/shocks is generally only valid on a 1.5" drop or less. Also discussed, slamming the car does NOT increase performance.
Old Apr 19, 2002 | 10:18 AM
NYCe MaXiMa's Avatar
too low
too ugly
put my rims on it then it will look
Old Apr 19, 2002 | 01:43 PM
breaux124's Avatar
I can't find it now, but Jeff K had a side by side pic of a stock maxima and his maxima with H&R's. There was a very noticable difference.
But looking at the car by itself, it doesn't look "dropped" but it does look better. When someone says dropped I think of those civics where the wheels are hiding inside the wheelwells. Each car has a different look, BMWs stock look like their lowered, but thats just how they come.
One of the great things about H&R springs are that they are progressive, which means they get stiffer the more you push on them. This allows for a good ride in normal driving and a stiffer ride/ response when you push them.
Old Apr 19, 2002 | 02:36 PM
vw1xvWL6's Avatar
Got H&R's
Not slammed, those who know about the 4X4 stock height will definately
notice the drop with H&R's
Old Apr 19, 2002 | 02:47 PM
vw1xvWL6's Avatar
Got H&R's
Old Apr 19, 2002 | 06:30 PM
nixima's Avatar
check my sig for 96SE, H&R, stock shocks, 225/50/16s.
Old Apr 22, 2002 | 05:26 AM
Lime's Avatar
tire size can make a difference too.
Old Apr 23, 2002 | 07:57 PM
PejMax97SE's Avatar
well which tire size will show the least gap with H&R's ?
i have the limited 5spoke 97 rims that are 16's.
Old Apr 23, 2002 | 08:08 PM
MaximaPower's Avatar
CHECK SIG PIC
Ant
man ur max looks tight...how's the ride with the one coil cut off?
is the ride more harsh then without cutting off one coil?
and do u scrape ur front lip alot?
bc992164
Nov 2, 2015 10:00 PM
tonydatigeryo
Jun 19, 2014 05:48 PM
PSU09MAXIMA
Feb 8, 2012 10:39 AM
jowo9
Sep 15, 2009 10:35 AM
