gas milage
Old Apr 19, 2002 | 07:59 AM
CatchnDolphn's Avatar
gas milage
anything i might be able to do to get my gas milage up? im only getting like 16 miles per gallon.
Old Apr 19, 2002 | 08:35 AM
95emeraldgxe's Avatar
dont stomp on the gas to hard, use premium fuel, get a cold air intake and a y pipe
Old Apr 19, 2002 | 09:55 AM
BRIGBOY's Avatar
Depending on your miles,
All of the routine maintenance. Filter changes, fluid changes, etc.
Old Apr 19, 2002 | 10:17 AM
Eric L.'s Avatar
If you make lots of short trips (under 5 miles), you will get horrible mileage. Recently I've been doing a lot of city driving with all short trips. I got 15mpg.
Old Apr 19, 2002 | 11:14 AM
mango95se's Avatar
Re: gas milage
clean out the throttle body, new fuel filter, maybe some fuel injector cleaner. 16 is very low - even at my lowest mileage with lots of city driving, i never get less then 20 mpg. Maybe you're leaking gas somewhere..
Old Apr 19, 2002 | 11:20 AM
sil SE's Avatar
how do you figure your mpg for sure?
Old Apr 19, 2002 | 12:50 PM
njmaxseltd's Avatar
Miles driven divided by gallons of gas used.
Don't they teach math in school anymore?
Old Apr 19, 2002 | 12:56 PM
iwannabmw's Avatar
Probably not
Old Apr 19, 2002 | 10:02 PM
i run 92 octane right now
Old Apr 20, 2002 | 07:57 AM
JettmiesterMax's Avatar
My mileage
I have over 100K on my 95GLE and avg 25-26 mpg and I make a lot of short trips. My jaunt to work every day is a 5 mile stop and go trip. I guess this Max has been very well taken care of. I Guess? I know it has!
Old Apr 20, 2002 | 09:21 AM
98BlaximaSE's Avatar
I was getting was low mpg for a while, then put in a new air filter for the stock box. mpg jumped back up, andi i'm getting 350-370 per tank now compared to the 270-300 before.
Old Apr 20, 2002 | 03:21 PM
im getting bout 270 a tank. give or take a little bit. and i just put a brand new k&n in not long ago
Old Apr 20, 2002 | 04:19 PM
Joseph77's Avatar
Correct me if Im wrong but wouldn't a cold air induction reduce your mpg?
Old Apr 21, 2002 | 12:07 AM
Savage42's Avatar
Looking at the setup on my newly acquired '97 SE Auto, the stock intake is a "cold air" setup as it takes in cool air instead of the air in the engine compartment. Studies show that a CAI setup is good for 7 HP for every 100 HP the motor puts out. Hot engine compartment air is a killer on HP.
BTW, I just put 1600 miles on the Max in one week. On both road trips, I pretty much cruised 85-90 mph (with a couple 100-110 blasts) and got 470 miles on one tank which took 16 gallons to fill. That puts it at 29.4 mpg. I run regular unleaded with a special additive that bumps octane several points and increases mileage. Got an extra 50 miles per tank in the Tahoe and it only gets 10 mpg. Stuff must work! Not a bad deal considering it's only $10 for a 12 oz. bottle and 1.5 ounces treats 18 gallons, so 8 tanks in the Maxima treated per bottle. That's .80 cents per tank which makes up for the .20/gal savings over super and increase mileage to boot. Oh, it's not sold in stores, either. I've read 28 mpg with an auto. Anyone else get almost 30 on hwy trips?
Old Apr 21, 2002 | 02:05 PM
whats that stuff called?
Old Apr 21, 2002 | 02:47 PM
Savage42's Avatar
It's called Freedom fuel additive. The bottle has a cool resevior that meters how much you want to add in .5 ounce increments.
Old Apr 21, 2002 | 02:54 PM
Soybadboy's Avatar
I live in So. Cali and I have an auto 95SE. I get like 20mpg in the city because I drive my car fairly hard and I race at too many stop lights. All I have is a K&N intake and my car reads 163,000 miles. I just went to Vegas and I got 32.5mpg. I was cruising like at 70mph with the AC on all the way. I did use Prolong's octane booster and I was very impressed.
Old Apr 21, 2002 | 04:00 PM
MAX_PA's Avatar
I don't know how many miles you have on your Max, but bad oxygen sensors can result in a real rich fuel mixture.
Maybe someone here could comment on whether it results in an ECU code that the dealer could read out.
I could be wrong but fuel injector cleaner is not recommended for Nissans. I know for sure that on my 91 SE-R I had a TSB that prohibitted the use of injector cleaner. I drove the car over 100K and never had drivability issues with injectors.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
