This Mod Rewire Blinkers
Old Apr 21, 2002 | 07:06 AM
Cmingo3490's Avatar
which color wires do u use when u do this mod... what is the color wire for the turn signal
Old Apr 21, 2002 | 08:47 AM
clee130's Avatar
This page has pretty straight-foward directions:
http://www.geocities.com/amixam69/nissan/markerblink/
Old May 8, 2002 | 06:51 PM
kmax's Avatar
I connected the green wire from the front directional to the black wire of the side marker like the link above said and poof out went the fuse. Does anyone know for sure that the green wire is hot and the black is not like that link above claims?
Thanks in advance.
Old May 8, 2002 | 06:58 PM
aznsap's Avatar
Thanks in advance.
UHHH....... ur supposed to CUT the black wire of the side marker and connect/splice it to the green wire of the turn signal.
Old May 9, 2002 | 03:00 AM
kmax's Avatar
Sorry I meant to say that I tapped a wire into the directional green and ran it to the side marker black. I then turned the directional on and with the headlights off the fuse blew.
Old May 9, 2002 | 05:21 AM
maximus75's Avatar
Just make sure as aznsap said, that you CUT the black wire and connect the BULB side of it to the GREEN wire which you do not cut.
Old May 9, 2002 | 02:54 PM
kmax's Avatar
Uhh, it goes to show that if enough people tell me to CUT the wire I will understand that this means Cut The Wire and it dosen't mean tap into it.
Thank you
Old May 9, 2002 | 03:15 PM
maximus75's Avatar
Thank you
Uhhh... well it's so simple to understand that we couldn't understand how you kept getting it wrong. So how about instead of being rude to people who are trying to help you you just say "thanks, I got it now"?
Old May 9, 2002 | 06:43 PM
kmax's Avatar
I did not intend to be rude to people. The intention of what I wrote was self depreciating humor. I'm sorry if you took what I wrote the wrong way. I did say thank you and that was meant for aznsap and you.
Old May 9, 2002 | 07:22 PM
maximus75's Avatar
Well...OK then
Old May 31, 2002 | 12:30 PM
jensyj's Avatar
rewired my blinkers and side markers
i did it.
i finally rewired my blinkers and side markers.
now when i put my directional lights to make either a left or right... my side lights blink also.
Sir Tilus
Mar 22, 2016 01:49 PM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
