Power Window Problems - Help!
Old Apr 23, 2002 | 10:46 AM
95SE
Hi all,
I have a '95 SE and the driver's window is having issues. It goes down all the way (but the motor won't stop running) AND it will only go up w/some help.
It seems like it's a bit loose in the channel, but I pulled the door skin and lubed the track and channels, and nothing seemed to need tightening. It was just loose (moves from side to side).
Is this a case of a worn out motor? Do the cables keep the window tight in the channel?
Any help is appreciated, thanks!
Old Apr 23, 2002 | 12:11 PM
GarthG's Avatar
Re: Power Window Problems - Help!
Originally posted by 95SE
Hi all,
Don't know if this is what it is but it sounds like the power window regulator has failed on your car. . . It was a fairly common problem on 3rd gens, but I know it has happened on my 95 also. Has the exact same symptoms.
Old Apr 23, 2002 | 02:10 PM
95SE
Is there a good source for these regulators that has a good reputation w/the Maxima community? I wouldn't mind getting it online if I knew that the businesses reputation was good.
Old Apr 23, 2002 | 02:53 PM
GarthG's Avatar
I think it is a dealer only part, but you could try Courtesy Nissan in Texas. . . They give us deals on parts. Other than that, you may try junkyards or just bite the bullet and get it from a local dealer. I know it was about $200 parts and labor when mine went out on my rear door.
Old Apr 23, 2002 | 04:00 PM
tyrotrader's Avatar
Mine went out on rear driver side too, cost about $200 fix P&L
Old Apr 23, 2002 | 06:30 PM
95SE
Thanks for the help guys! I am ordering the regulator thru www.tustinnissan.com for $56. They give folks who mention the forum 20% off list which is pretty good.
Thanks again
Old Apr 23, 2002 | 08:57 PM
Pappa Grande's Avatar
Let us know how it works out. I ended up getting a new motor at a junkyard when it happened to me.
Thanks again
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
The Frye
Feb 3, 2019 08:34 AM
trungg86
Sep 4, 2015 04:58 AM
