exhaust ?????
Old Nov 27, 2000 | 07:38 AM
maximadan96's Avatar
ok my car exhaust noise is to loud with the y-pipe and the custom b-pipe and i wanted to get a muffler that will make my car quite.
sow what muffler should i add i heard that the HKS is preety quite but 1 of my maxima friends said just to add a 2000 maxima stock exhaust what muffler should i pick or is there another 1 that i can pick?????????
Old Nov 27, 2000 | 08:38 AM
Daniel B. Martin's Avatar
If you want quiet operation go back to a factory stock exhaust system. Don't install a 2000 Maxima exhaust system, because
- It won't fit right (2000 Maxima has a longer wheelbase).
- Your Engine Control Module lacks the capability of operating the active muffler.
Old Nov 27, 2000 | 04:14 PM
Confused's Avatar
Permanent Maxima.org Resident
Are you saying the valve in the 2k muffler has a sensor controller by the ecu?
QUOTE]Originally posted by Daniel B. Martin
[/QUOTE]
Old Nov 27, 2000 | 05:42 PM
Re: Are you saying the valve in the 2k muffler has a sensor controller by the ecu?
You have it almost right. A sensor is something which sends a signal to the Engine Control Module (example: the Oxygen Sensor). An actuator is something which receives a signal from the ECM and acts in response to it (example: the fuel injectors).
The 2000 Maxima has an active muffler. It has a special valve which is closed at low RPMs and open at high RPM. For more information, go to the Nissan-USA site:
http://www.nissandriven.com/frameset_maxima.html
and click on Performance.
Old Nov 27, 2000 | 06:29 PM
Confused's Avatar
So it's electronically controlled and not by pressure?
Old Nov 27, 2000 | 06:41 PM
Re: So it's electronically controlled and not by pressure?
I must admit, I don't really know. After reading about it, I assumed it was electronically controlled...
Old Nov 27, 2000 | 09:00 PM
SleeperSE's Avatar
Active Muffler
...If you want quiet operation go back to a factory stock exhaust system. Don't install a 2000 Maxima exhaust system, because
- Mr. Martin, I thought that the "active muffler" was operated based upon exhaust pressure opening up a second valve, not the ECU. Is the system electrical in nature?
Old Nov 27, 2000 | 09:12 PM
Confused's Avatar
Quite honestly, I believe it's by pressure
because there are no wires hanging out of the muffler.
Old Nov 28, 2000 | 12:28 AM
I30CeFiRo's Avatar
Pretty much any aftermarket exhaust will be loud with the Y-pipe. Putting on the stock exhaust is the only way to quiet it down
Old Nov 30, 2000 | 08:35 PM
wicked1044's Avatar
works with pressure...
Old Dec 1, 2000 | 12:03 AM
BrianV's Avatar
I read on the I30 when it came out that it's electronically controller!
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
TheMafia
Sep 4, 2015 08:26 AM
