Question about import intelligence needles w/ rev. gauges
Old Apr 24, 2002 | 07:09 PM
99MAXSE-L's Avatar
ok,i want my guages to look EXACTLY like these...
Ben's 97 Maxima...
http://www.cardomain.com/member_page...77_62_full.jpg
http://www.cardomain.com/member_page...77_61_full.jpg
I might be getting another maxima for myself, (the one in the pic is my sisters) and the problem is that those needles only fit 97 maximas, and not 98-99...the 98-99 maximas have those needles only in hyper red from www.importintelligence.com
now, i dont wanna buy a 97 maxima just for these guages...so if i get a 98-99 maxima, and take the needles from a 95-97 maxima, and install them in a 98-99 maxima...how hard would that be?? is it possible?
and where can i get those reverse indiglo gauges from??
Old Apr 24, 2002 | 07:13 PM
xsp00kyx's Avatar
Re: Question about import intelligence needles w/ rev. gauges
Ben's 97 Maxima...
hey i asked the guy at importintelligence.com and he said if you have an SE model maxima then those needles will fit and how come the second picture only has the needles lit? what about the numbers?
Old Apr 24, 2002 | 07:15 PM
99MAXSE-L's Avatar
i think he dimmed them in that pic...
however, why in only a SE??
i have an SE, and the needles are orange...
Old Apr 24, 2002 | 07:36 PM
Ramius83
Ok, first off, he dimmed the reverse indiglos.
Second, you can get clear needles off a 95-97 Maxima and replace your orange ones with the clear needles.
Third, it works with all needles. Some people for some reason think that only the "sport edition" will work with their kit. If you don't believe me, check out the eBay sellers lol, it is pretty funny stuff. They say SE to get your attention, that is all.
Fourth, the reverse indiglos are on eBay for like $33.95 or something like that, very cheap.
I have my set-up the same as Ben's, but I had it first, (for over 1.25 years now), but I don't have any pics lol. So I guess he gets credit. Also, you want to make sure that you get two blue LED 194s to go in your gauge cluster to light up the odometer/tripometer if you have a 95-97. Good luck with the kit guy.
If you don't think I know my stuff, take a look at what I did with my friends 00' Sport Dodge Ram. We bought the 6 needle kit (2 big and 4 small needles) and installed them under the needles. Took the orange backing off the needles and painted the back of the needles blue. Bought some 194 gauge cluster bulb bases from Nissan and put some blue LED 194s in them and put that in his Dodge cluster. Turned everything on for the first time and BAM, everything was blue, just like mine and Bens..... .....I'm good...
Old Apr 24, 2002 | 07:40 PM
Krash513's Avatar
I have the same gauges in my 97 SE, ive heard they will work on a 98-99 as long as its an SE. You can get the gauges on ebay for around $40 shipped. I have the damn stock orange needles too, but at night they actually look pretty close to the red color in the gauges so it looks sweet. My tach is sticky from the gauges....so i still havent figured out why yet. But get the gauges youll be happy with them. http://cgi.ebay.com/ebaymotors/ws/eb...2&r=0&t=0:eek:
Old Apr 24, 2002 | 08:04 PM
Krash513's Avatar
Heres that link again
click
Old Apr 24, 2002 | 09:36 PM
Maximus97's Avatar
So the reverse gauges are the ones the light up the numbers and not the faces right? Also, how does the brightness change, does it have a **** like on our OEM gauges or is it the little push button pad?
Old Apr 25, 2002 | 07:16 AM
Krash513's Avatar
With my setup the old dimmer switch still works, but because the gauges actually go over the stock ones, it only dims the radio, clock, needles and odometer. The reverse indiglos come with a dimmer and color changer switch that works the new gauges. And yeah with reverse indiglo it lights up the numbers not the face
Old Apr 25, 2002 | 07:29 AM
Maximus97's Avatar
Where are you putting the new dimmer switch to control the gauges? Also in Ben's 97, does he have the indiglo needle kit with it? Is it possible to install both the reverse indiglo gauges with the indiglo needle kit? It thinks it looks great!
Old Apr 26, 2002 | 11:56 AM
99MAXSE-L's Avatar
Maximus97:
yes...he along with reverse indiglo guages has the needle kit, which in my opinion is absolutly astonishing!!
Ramius83:
Ok so, will these REVERSE indiglo guages fit 98 and 99's???
and i know that the needles wont fit with 98-99s, but as u said, u can replace them with 95-97 needles that are clear...
Krash513:
U have the orange needles? the whole point is to also get these blue needles, which will match with ur gauges. What do u mean by sticky?? do the needles stick to the guages???
**so therefore, there is no purpose in just buying a 97 maxima for this setup, because it is possible with 98-99's...correct???
PROBLEMS: anyone have any problems with their setup?? (Ramius83), like problems with the needle kit, and guages???
Old Apr 26, 2002 | 12:52 PM
maximus75's Avatar
99Maxse, The neddles in 97's are also orange. When I did mine I bought a 96SE cluster from a junkayard and took the white needles off of it. I don't see why you couldn't do the same. You can sand the paint off the back of the orange needles and paint then white or blue but the factory white needles look much better. Just make sure you get a reverse indiglo guage set for a 98-99 cause you have a digital OD in those years.
Only problem I had was that the holes for the needle rests were too large and the needle rests wouldn't snap in like they did on the factory guages. I used a hot glue gun to hold them in place.
I would also suggest useing a hot glue gun to hold the guage faces in place because using double stick tape holds the guage up a little to high and the needles tend to stick.
Old Apr 26, 2002 | 01:05 PM
itsgt's Avatar
Old Apr 26, 2002 | 01:21 PM
maximus75's Avatar
itsgt, what size tubes did you use under your dash? Are they Streetglow?
Old Apr 26, 2002 | 01:30 PM
JsL's Avatar
JsL
Its weird how nissan changes the position of the fuel and temp guage, don't you think so? I've been trying to look for reverse indiglos for my 1998 I30, but have had no luck. I have a digital odometer and my fuel guage is on the left and temp guage is on the right.
Old Apr 26, 2002 | 01:33 PM
mtrai760's Avatar
'Trynna' is not a word
Ive got a set of Reverse indiglo's I want to get rid of. I tried installing them 3 or 4 times, but the needles would always stick, no matter how much double sided tape I used...
Old Apr 26, 2002 | 03:13 PM
maximus75's Avatar
Use a glue gun!
Old Apr 29, 2002 | 07:43 AM
Maximus97's Avatar
I also have the orange color needle in my 97. What if I was to use the red needle kit with the reverse indiglos, anyone ever tried this? Would it look alright? I would like to do the blue needle kit, but it doesn't look like this will be a possiblity with my orange needles. What do you think?
Old Apr 29, 2002 | 07:54 AM
maximus75's Avatar
I don't think the red would look good. Yo can scrape the orange paint off the back of your needles and paint them blue or white. Or, you can go to a junkyard and get a cluster for a 95-96 SE. I would do one of these and get the blue led's.
Old Apr 29, 2002 | 12:32 PM
mtrai760's Avatar
So I use a glue gun, it doesn't work, now Ive got guages permanantly attached with needles that don't work, doesn't seem like a very good idea to me...
Originally posted by maximus75
Use a glue gun!
Old Apr 29, 2002 | 02:03 PM
99MAXSE-L's Avatar
yah, so u can either buy it from the junkyard, or u can get like blue paint, and paint over ur needles...i was thinking that blue paint that comes with model cars that u build...
Old Apr 29, 2002 | 02:21 PM
maximus75's Avatar
Maybe you've never used a glue gun. It isn't permanent, thats whats so nice about it. But what do I know, I've only done 7 sets of these gauges, none with any problems.
Old Apr 29, 2002 | 09:31 PM
brodaiga's Avatar
I have a 96 SE, so from what I understand, i buy reverse indiglo guages and intelliglow needle kit. What is this talk then about putting additional blue 194's in the guage cluster, how is this done? What is the difference in looks if you don't put the 194's? Is the very first picture in this thread with the 194's? In your opinion, what looks better? Thanks.
Old Apr 30, 2002 | 01:13 PM
FJC's Avatar
FJC
Same question, bump..
Old May 1, 2002 | 05:51 PM
99MAXSE-L's Avatar
Since u have a 96, u have odometer that is not digital. u can put in a blue blub in ur cluster so that it glows blue and not the stock blub color, it will then match ur needles/indiglos...
Old May 1, 2002 | 06:05 PM
99MAXSE-L's Avatar
these reverse indiglos will not work with 98-99's right???
reverse indiglos
Old May 2, 2002 | 02:10 PM
99MAXSE-L's Avatar
bump~
Old May 2, 2002 | 02:43 PM
maximus75's Avatar
bump~
You have to make sure it has ONE cutout for the didgital OD. I would EM them and ask. Let them know that the 97 is diiferent from the 98-99. I know of some other members who have ordered guages fo a 95-98 who have 98's and the gauges were wrong.
Old May 2, 2002 | 09:09 PM
mtrai760's Avatar
Well then, why dont you come on up to WA and do mine for me? Seriously, I have used a glue gun, but for reverse indiglo's, it's just not worth the hassle to me. I used enough double sided tape to stick my car to a ceiling, and the gauges still didn't stick right, I don't find them all that cool and must have, I rather add something that makes my car go faster. All go, no show...
Old May 3, 2002 | 07:47 AM
maximus75's Avatar
Let me try and help you with this. Your saying the guages won't stick no matter how much tape you use, hence my suggetion to use a GLUE GUN. In a previous post you said you tried it 3 or 4 times but the needles would always stick. Why? too much/ too thick tape. Again this is why I suggested a GLUE GUN. If you don't like the idea of using a glue gun then don't but don't go flaming me for it. Maybe it will help someone who wants the gauges.
BTW I'll be more than glad to do yours but you'll have to bring them to NY. It'll take about a half hour.
Old May 3, 2002 | 09:41 PM
mtrai760's Avatar
I wasn't trying to flame you, see the mood lightning smilie I added? I think your idea does have merrit, I'm sure it worked for you and would probably work for me too. However, I personally dont want to go to that extent to mount the gauges. Nothing against you. Thanks for adding in the glue gun part, I never thought of trying that, and I know a LOT of people have had trouble with sticking gauges, so hopefully this will help some people out. As always...
Old May 3, 2002 | 10:56 PM
maximus75's Avatar
No prob, but seriously the reverse indiglos look really nice. You should install them.
Old May 4, 2002 | 06:38 AM
99MAXSE-L's Avatar
yah there great, thats why im so interested in them
Old May 6, 2002 | 09:36 PM
FJC's Avatar
FJC
Are those the ones on ebay? Unitedindiglo?
Old May 21, 2002 | 12:28 AM
pkim23's Avatar
you said that you needed some 194 wedge bulbs for that cluster... do you mean hyperwhite or blue blue? and how many? just replacing 2? or do you have to replace them all? thanks...
pkim23
Old May 21, 2002 | 02:25 AM
black019's Avatar
Ben's 97 Maxima...
that looks sweet
Old Jun 26, 2002 | 11:56 PM
infinit30t's Avatar
who makes reverse indiglos for my 98 i30t?
I have been trying to find these for a while and can't seem to find the right ones.
Old Jun 27, 2002 | 11:19 PM
98fiveSpeed's Avatar
so which ones will work for a 1998? can u post some links?
Old Jun 28, 2002 | 01:40 PM
*bump*
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
