warm startup
Old Apr 28, 2002 | 07:34 AM
todd_zh's Avatar
warm startup
got a problem of warm startup, especially after the car being exposed for a while in a hot sunny day, it takes longer to start the enginee. Sometimes step on acceslator may help. A computer check by dealer shows i have to replace a Knockout sensor and a ventilation control valve. They are all costly and I have not idea of necessarity of these replacement. Any advice would be greatly appreciated
Old Apr 28, 2002 | 08:39 AM
oppaman's Avatar
Re: warm startup
The owner's manual recommends keeping the
accelerator fully depressed whenever
restarting withing half an hour on a hot
day. Not sure why that is...sounds to me
like you don't want to hit 3000-4000 RPMs
on an engine which hasn't received oil
for upto 30 minutes? I believe *all* oil
is drained within 4 hours after shutting
down the engine.
Interestingly, I read somewhere recently
that *hot* restarts (i.e. within a few
minutes of a fully warmed engine shutdown)
aren't such a good idea--better to let
the car sit for a while. This is especially applicable during a car's
break-in period.
Old Apr 28, 2002 | 10:15 AM
95emeraldgxe's Avatar
Re: warm startup
my car had the exact same problem!!! - on days hotter than 90F, it took me forever to get the POS started. took it to the dealer, they replaced the starter.....seemed fine for a few days, until the problem occured again. the problem turned out to be something wrong with the alarm.........they changed that for free and no more problems.........do u happen to have an automate alarm ?
Old Apr 28, 2002 | 01:51 PM
todd_zh's Avatar
Re: Re: warm startup
Thanks so much for advice. This baby has many alarms.....not sure which one you changed. Can u let me know?
Old Apr 28, 2002 | 02:33 PM
nadir_s's Avatar
vicodin ... gift of life
Re: Re: Re: warm startup
Check the starter relay... when ure alarm is armed, it cuts power to the starter... sometimes in the heat, it becomes "sticky"... i had that problem too, then i ended up having a starter button installed that bypassed it.
Old Apr 28, 2002 | 04:22 PM
todd_zh's Avatar
Re: Re: Re: Re: warm startup
I believe the startor works fine....i heard the sound, just the engine took longer to ignite....don't know why..
Old Apr 28, 2002 | 04:55 PM
TooCold96's Avatar
i got a 03 04 on my ecu test and i did notice it does take a while it to start also .do i need to change it?
Miket2006
Mar 1, 2021 03:55 AM
msellas
Sep 23, 2015 09:16 PM
carid
Sep 17, 2015 05:00 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
