Door Handle Coming Out
Old Apr 28, 2002 | 09:08 AM
MICHAELCORY's Avatar
I need help!! My outter door handle on the driver side is coming out literally, like someone tried to pop it out. I look and saw no damage (paint scratched). Now I can not open my drivers side door. I tried the search engine but found no information on how to fix the problem. Thanks for any help you can give?
Old Apr 29, 2002 | 02:16 AM
MIXXMAX's Avatar
Re: Door Handle Coming Out
Take off the inside door panel and you'll see the handle exposed from the inside. Tighten up the two retention bolts on each side. Hopefully, this should cure your problem.
Old May 9, 2002 | 09:21 AM
Porcupine's Avatar
Re: Re: Door Handle Coming Out
I have the same problem and will see if this takes care of it.
Is the black molding around the outside of the door handle assembly "self-sealing" just from the tightness of the retention bolts or do I need to put something on it to seal it?
Old May 9, 2002 | 08:49 PM
MIXXMAX's Avatar
Re: Re: Re: Door Handle Coming Out
I believe the black molding around the outside door handle is part of the handle itself. It should tighten flush with the door when the retention bolts are fastened.
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
