ecu code 04 03.knock sensor.what do i do???
Re: ecu code 04 03.knock sensor.what do i do???
Originally posted by TooCold96
what am i supposed to do .??????????
I'd reset the ECU. Recheck it a couple of starts later. If it still has a 03 04, replace it. Supposedly, you can check the sensor for continuity with an Ohm-meter. It's supposed to have a really high resistance, on the order of M Ohms. If it is infinity, then supposedly it's bad. Of course, you cant just pull the harness and measure from the two leads because only one lead goes to the sensor. Measure the signal lead and the ground from the car (the KS case is grounded). Tested mine today and it was bad.
How2 that is excellent:
http://www.skippynet.com/maxima/knocksensor.htm
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
