POLISH OUT YOUR VALVE COVER & OTHER LINES
Old Nov 15, 2005 | 04:30 PM
  #81
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
im doing the intake manifold i used a air grinder with a stone wheel and i got all the rough stuff off and then i used 50 grid and then 60 and then 100 and when i finish the 100 next would be wet 400 600 800 1000 1500 and polish its going to take forever
Old Nov 15, 2005 | 04:51 PM
  #82
lilaclucymaxima's Avatar
Team Ramrod
Nice post/writeup, definitely worth the time put into it. I will most likely do mine once the winter is over with.
Old Nov 15, 2005 | 05:20 PM
  #83
86maxima96's Avatar
I Broke OT
what is it that's on the IM? is it some ceramic coating or what? a grinding wheel is probably a good idea for that stuff.
for my VC, first i washed it a few times with dish soap to degrease it a little bit. then the first overall sanding i did seemed to get most of the gritty and rough surface off. it's already much smoother to the touch and a bit shinier. i'm sure it'll look great after a few more hours. (or more)
i'm doing the VC now and then picking up an upper IM over Thanksgiving. hopefully i can have them both done by the end of winter and install them then and have a b itchin bay!
Old Nov 16, 2005 | 11:45 PM
  #84
D-Bo's Avatar
Droppin logs
Originally Posted by Jar
Not trying to sound lazy here but after you do this is there a way to make it last longer than a couple weeks, like some kind of clear coat or protectant that could be sprayed on or rubbed on??
Wutz up bro? I know of a product called Zoops that's something the hot rod gus use to protect their polished aluminum. You can get it from eastwood.com along with other aluminum polishing accesories. I was really thinkin of doin this too.
Old Dec 4, 2005 | 09:26 AM
  #85
ny96max's Avatar
BUMP!
Ant
Old Dec 26, 2005 | 03:16 PM
  #86
VQuick's Avatar
Chassis Freak
I just removed my front valve cover. Should I remove the circular rubber spark plug gaskets or leave them in while sanding and polishing? Only reason I ask is I don't want to damage them putting them in and out.
Old Dec 26, 2005 | 08:36 PM
  #87
Nismo3112's Avatar
Custom User Title
I left them in.
Old Dec 26, 2005 | 08:43 PM
  #88
Team Ramrod
Originally Posted by naplesmaxima aka Tommyali the scammer!
omg this is more work that i thought i've been doing it for 6 hours now and im no where close to being done
Maybe you're just a weak little girl
Old May 2, 2006 | 07:17 PM
  #89
HallKemar
^DONT BE SEXIEST...but yeah, u are a little girl!!!
Old Nov 26, 2006 | 03:45 PM
  #90
ColombianMax's Avatar
BUMP, excellent thread/write up...Will be starting probably this Wednesday when I pick up aspare plentum from junk yard for 8 bucks, so I'll be working on it this winter so its perfectly mirror like for summer or perhaps way before
Old Jan 17, 2008 | 04:51 PM
  #91
t6378tp's Avatar
Turbo 3.5
bump for a good thread
Old Jan 17, 2008 | 05:12 PM
  #92
thanks for that bump, I was lookin for this
Old Jan 17, 2008 | 05:30 PM
  #93
1year and counting..........Never got around to it, eh?
FWIW, this thread is probably stored in your "subscribed threads".....
Old Jan 17, 2008 | 05:46 PM
  #94
Yea I got an email as soon as he bumped...can you actually check what threads you're subscribed to?
Old Jan 17, 2008 | 05:54 PM
  #95
Yes sir, it's in your "User CP" under "List subscriptions". You can even have folders for organizational purposes.
Old Jan 17, 2008 | 11:33 PM
  #96
t6378tp's Avatar
Turbo 3.5
well I was painting my rear caliper and got bored waiting between coats so I started polishing my oem intake. this is the result after about 1hour of work and stoping with 400 grit sandpaper it's the highest I had around, I plan to finish the whole thing for practice cause I plan to do my mevi and front valve cover soon. if anyone wants this intake when I am done it will be for sell cheap. it will be awhile before it's done but I am very happy to see what I can do in just 1 hour
Old Jan 19, 2008 | 12:51 PM
  #97
VQuick's Avatar
Chassis Freak
Lookin' nice, but doing the other 5 and all the crevices will take a long time. Post a photo when you're done!
Old Jan 19, 2008 | 03:17 PM
  #98
t6378tp's Avatar
Turbo 3.5
updated pic after a days work, I still need to sand and polish it but it's getting there
Old Jan 20, 2008 | 09:09 AM
  #99
t6378tp's Avatar
Turbo 3.5
well since I never planned to install this on my car and was only doing this to kill time I am done for now cause I have a mevi to polish.
but if I get bored again I may polish it somemore but not right now
Old Jan 20, 2008 | 10:40 AM
  #100
97maximaman's Avatar
Wow, real nice so far, how many hours of work is that? I've been planning on doing valve cover, timing chain cover, manifold and the little parts like radiator pieces. Just never seemed to work out well. I tried using strictly mag polish but it isnt coarse enough at first.
Old Jan 20, 2008 | 11:41 AM
  #101
got_max's Avatar
Wants a real car
a question with the timing chain cover. To polish it and sand it, do you have to take off or do you do it while its still on the engine? as well as for painting. how do you get so much of it painted without getting paint everywhere else?
I just finished my intake manifold and looks just like above. My valve covers are both done but now everything else on the engine looks so out of place
Old Jan 20, 2008 | 01:02 PM
  #102
t6378tp's Avatar
Turbo 3.5
I would say about 8hours or less it really did not take long at all, it's for sell if you want it
Old Jan 20, 2008 | 01:51 PM
  #103
I'd buy it but im broke, lol. Just started a new job so in a few weeks if no one buys it maybe i'll pm you.
Old Jan 20, 2008 | 05:18 PM
  #104
t6378tp's Avatar
Turbo 3.5
No rush, I may even polish it alittle more by then away
Old Jan 20, 2008 | 05:23 PM
  #105
Just curious, did you use any power sanding tools, like those flap drums or anything. And what grit sequence did you use? 220, 400, 600, 800? I was thiking of using a dremel or power drill with sanding drums for the 120, first sanding, then go by hand after that on my valve cover.
Old Jan 20, 2008 | 05:29 PM
  #106
KRRZ350's Avatar
^^That's the way to do it.
Also, the sandblaster discs plus attachment for grinder are very useful.
Having a heavy duty 7/8" polisher (AKA a $200 buffer) helps out alot......
I'll edit this post with notrmal pics of the 3.5 I just did shortly, but the sig should do for now. My av and sig are teh hawtness..........
Old Jan 20, 2008 | 05:35 PM
  #107
Amen to that, you arent lying
Old Jan 20, 2008 | 06:41 PM
  #108
t6378tp's Avatar
Turbo 3.5
I used a grinding wheel on a drill to get the ruff stuff off then a 60 and 240 grit drum on the dremel to smooth things out alittle.
This is all I had sitting around the house, I did not use 400, 600 and 800 grit yet.
Old Jan 20, 2008 | 06:44 PM
  #109
t6378tp's Avatar
Turbo 3.5
hopefully when I do my mevi it will look like that. I did not want to spent alot of time on the oem intake just get a idea of whats needed to polish it
Old Jan 21, 2008 | 08:45 AM
  #110
KRRZ350's Avatar
Old Jan 25, 2008 | 07:11 AM
  #111
t6378tp's Avatar
Turbo 3.5
well someone has taken this off my hands so I will not be bringing this to a mirror finish like Kev's
Old Jan 26, 2008 | 02:53 PM
  #112
t6378tp's Avatar
Turbo 3.5
well I got bored today and spent about 2hours on my valve cover. this is with 240 grit sandpaper, I'll be hitting up the store for some 400 and 600grit soon. got to get that mirror finish like Kev
Old Jan 27, 2008 | 12:20 AM
  #113
redmaxpa007's Avatar
i SeE what you did therE
yeah, but the rest of the engine bay....
holy no elbow grease batman!
Old Jan 27, 2008 | 01:39 AM
  #114
t6378tp's Avatar
Turbo 3.5
1 step at a time young skywalker
Old Jan 27, 2008 | 01:41 AM
  #115
Jess's Avatar
SHIFT_In2D
Hmm I may think about doing this sometime soon. Used to polishing things out now lol. But not sure if it will affect the heating / cooling of the manifold. Is it bad at all to do this?
Just wanted to make sure, because I read somewhere that it holds heat in more so when it's polished.
Old Jan 27, 2008 | 01:44 AM
  #116
your lucky this is the only pic i have online of my old 4th gen engine bay....
young skywalker my ****!!
Old Jan 27, 2008 | 02:25 AM
  #117
Jess's Avatar
SHIFT_In2D
It's so reeeddd!!
Old Jan 27, 2008 | 03:48 AM
  #118
t6378tp's Avatar
Turbo 3.5
I know for a fact you did not do it all in 1 day cause your intake manifold is not even polished
so like I said before 1 step at a time this was only after 1-2hours of sanding
Old Jan 27, 2008 | 04:46 AM
  #119
my engine bay was never dirty, almost every day i would clean it out. and it helped i bought it new..
intake manifold is not polished, valve cover... that is a different story..
and i will agree, it is a step by step process to get it where you want it to look...
Old Jan 27, 2008 | 07:36 AM
  #120
t6378tp's Avatar
Turbo 3.5
buying it new really helps, I had to start with 10years of packed on dirt/grease
