POLISH OUT YOUR VALVE COVER & OTHER LINES
Old Nov 27, 2000 | 04:30 PM
ny96max's Avatar
ok, so you want to polish out your engine to look like a mirror. This is what i have done and would reccomend:
1) remove plastic cover (nissan v6 lid)on the valve cover
2) - sponge with a scrubby side to it
- bottle of palmolive (green one)
*** make sure engine is cold and too cover up the ignition coils with towels to prevent water contacting them***
3) wash down the entire valve cover with small amounts of water and palmolive soap with the scrubby sponge. Palmolive is a degreaser and will remove any contaminents on the valve cover itself.
4) If needed get a brillo pad and rinse out all of the soap in it. Use the palmolive soap again and scrub the $hit out of the valve cover, till somewhat clean.
5) Dry completely
6) get out your aluminum polish
- Mothers: mag/aluminum polish (small can $5)
- Meguiars: rim/aluminum polish (small can $8)
7) use a cotton towel and apply a fair amount of the polish to the valve cover, kinda like your waxing your car
8) let sit for 2min then buff off vigorously!!
9) repeat these steps until a briliant shine appears
***for anyone else who wants a MIRROR LIKE SHINE ***
1) buy wet sand paper (Black) at any hardware store
a) 400 gritt
b) 600 gritt
c) 800 gritt
d) 1000 gritt
e) 1500 gritt
2) use a spray bottle and mist the valve cover in small sections at a time.
3) start off with the 400 gritt paper. go over the area in long-wide strokes, while pressing fairly hard
4) repeat step3 with the 4 other sheets of sand paper goin in order from 400-1500
5) dry off engine
**once dried it will look all scratched up, this will go away once you buff out the cover with polish**
6) use your aluminum polish and polish the crap out of the valve cover again
7) repeat step7 enough times till you see a mirror appear!
POLISHING OUT OTHERS just with the polish itself:
a) radiator cap
b) A/C lines running along side engine
c) coolant lines near the belts and behind engine by throttle body
d) any bolts/brackets that are metal will polish out after time to look like chrome
e) throw out black oil cap and buy a chrome or aluminum one to match your new engine
Once all of this is done make sure to try and keep the engine polished atleast once every two weeks, or else all your work will slowly fade away. I go over mine once a week to keep it lookin new. Good luck!
Anthony
Old May 31, 2002 | 10:27 AM
emax02's Avatar
This is a good post Thanks for the tips Anthony!
Old May 31, 2002 | 10:58 AM
CKNY's Avatar
any pics of how it came out?
Old May 31, 2002 | 11:12 AM
i999Maximagirl's Avatar
pull out your sunglasses Chris...its sooooooooooooo shiny.
Old May 31, 2002 | 07:22 PM
alexamparo's Avatar
so where is it???
Old May 31, 2002 | 07:36 PM
redmaxpa007's Avatar
i SeE what you did therE
a dremel with a polishing tip helps too
Old May 31, 2002 | 09:11 PM
1HOTMAX's Avatar
i don't understand???
so i use sand paper and scrub it with soap water and then?
and then?
and then?
oh and the palmolive, where does that go?
i need help, i'm confused man......
Old May 31, 2002 | 09:39 PM
DeRaNgEd's Avatar
Re: i don't understand???
and then?
and then?
When I have the chance I will do this to my valve cover.
THANKS!!!!!!!!! You have been a huge help!
Old May 31, 2002 | 10:06 PM
emax02's Avatar
Damn I have spent half the day doing this so far and I am not even close to being done. I removed my intake manifold and runners too
Old Feb 14, 2005 | 01:18 AM
s0ber's Avatar
bump... =) jea jea its 2005 now baby.. lol
i've been looking for this thread for years, time to bump maybe someone else will notice it =D
Old Feb 14, 2005 | 01:26 AM
nubiannupe's Avatar
OG Maxima.org Member
You should link this at the general forums - this is something that everyone could use, from an information standpoint...
Old Feb 16, 2005 | 03:17 PM
s0ber's Avatar
Here's my progress...
I need a dremel to get into the small areas that sand paper doesn't do much O_O
Old Feb 16, 2005 | 04:23 PM
_ck69_'s Avatar
Can you post pics of it when you put it back in your car.
Old Feb 16, 2005 | 04:38 PM
naijai's Avatar
yes please so
Old Feb 16, 2005 | 05:33 PM
s0ber's Avatar
Indeed
I sure will.
Old Feb 16, 2005 | 05:42 PM
kcryan's Avatar
thanks for the write up
Old Feb 16, 2005 | 05:55 PM
ny96max's Avatar
this post was from 5yrs ago and still going!!
that has to be a record or something, lol
**UPDATE 2005***
POLISHING YOUR INTAKE MANIFOLD:
1) buy a metal grinding wheel from your local hardware store or home depot($6)
2) Get out a corded drill or air drill and attach your grinding wheel and go to town
3) Start by doing one plenum on the manifold at a time working your way from the back to the front then do the inside seems and outter edges (you may want to remove the throttle cables and other misc brackets to avoid hitting them with the grinding wheel and sandpaper) also keep in mind its not totally necessary to go all the way to the back of the manifold or around to the throttle body, just doing the visible plenums up front is enough to keep peoples attention away from the parts you didnt do
4) Once you have the rough surface taken down start your sanding process.
5) Refer to my polishing methods up top steps #1-7... these steps will take ALOT longer than you think to make the surface of the manifold perfectly smooth. Eliminating every minor dimple in the manifold will take alot of effort, but the more you eliminate and smoother you get it, the more it will resemble chrome (my manifold took me about 2weeks, goin at it for a few hours every other day)
6) remember to re-polish the manifold a few times right after you do this to keep that heavy shine to it (when the motor is cold)
**OPTIONAL**
7) go to pep boys and pick up 10mm and 12mm chrome bolt/nut caps... they cost about $7 for a pack of 6, use these to cover up all the misc bolt heads and nuts around the engine bay. Its a good way to add extra bling to your engine compartment for very little money!
Ant
Old Feb 16, 2005 | 06:35 PM
RockfordMax's Avatar
Back from the dead
BEAUTIFUL, thats exactly what ive been looking for for a long time. wow, this sure is one vintage post. my car was only 5 years old then, lol
Old Feb 16, 2005 | 06:47 PM
dawalkster's Avatar
is craving Bojangles
someone please sticky this or make it a how to before it becomes another 5 years before we get a how to on polishing things.
Old Feb 16, 2005 | 07:50 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
sometimes it helps to dig up an old thread on a question that's probably been asked 10 million times by now
I agree, this is a useful post, can't wait to start on this when the weather gets warmer
Old Feb 16, 2005 | 09:04 PM
1HOTMAX's Avatar
vintage indeed!
now i need to do it again! if i still have the will power!
Old Feb 16, 2005 | 09:19 PM
G4nismo's Avatar
polishin takes sooo much damn work. i started with the steel wheel thing and looks ok but not totally mirror or anything. its not smooted out either but i can imagine how much work takes gonna take. IMOP, i don't think its worth it unless your going for show or something.
Old Feb 16, 2005 | 09:56 PM
maxspeed96CT's Avatar
The original VQ...
gona try it with some screws and small parts, when you say buff, do i realy need a buffer or can i use a drill bit thingy?
Old Feb 16, 2005 | 10:25 PM
Max Mutes's Avatar
This is amazing...
Old Feb 16, 2005 | 10:53 PM
Crockpot's Avatar
niiccee... found my new weekend project
Old Feb 17, 2005 | 09:34 AM
ny96max's Avatar
you can buy a buffer wheel at any local hardware store for a couple of bucks... this helps speed up the process, but you can always do it all by hand. Just plan on spending alot of time doing so. I didnt bother polishing all the brackets,nuts,bolts,FSTB and brackets etc... i just had them all chrome dipped instead to save time. My intention the entire time was a "show look" and i think i accomplished that
chroming cost me around $3-400 for everything to be dipped except my intake manifold, valve cover and timing chain case.
Ant
Old Feb 17, 2005 | 10:19 AM
2 Da Max's Avatar
i did mine but it has scratches on it
Old Feb 17, 2005 | 10:40 AM
s0ber's Avatar
keep sandin O_O
mine has small scratches but there going away =D
Old Feb 17, 2005 | 11:37 AM
95CustomMaxima's Avatar
Can't believe this post has been bumped up.. I remember seeing this post along time ago... Great Post!!
-Nick
Old Feb 17, 2005 | 01:14 PM
Max Mutes's Avatar
Ant
How long did it take for the stuff to get dipped in chrome? I guess I'm actually askin, did you have any down time with your car? I was thinkin about dippin my parts in chrome, but I need my car everyday and can't afford to have a place ship them away to be dipped...
Old Feb 17, 2005 | 04:14 PM
VQuick's Avatar
Chassis Freak
Ant
Judging by that photo you were able to successfully remove the plastic/rubber boot part of the hood security switch from the metal bracket. How did you do that? I can't get it apart for the life of me and it'd be much easier to clean up if I could get the metal separated.
Old Feb 17, 2005 | 04:31 PM
JetBlackMax83's Avatar
Very nice thread I deff have to hit up the engine with a scrub and sanding and some polish in like a month when its warm
Old Feb 26, 2005 | 11:10 AM
tzmanles's Avatar
i'll be doin this too when it gets warmer
Old Feb 26, 2005 | 01:39 PM
SMX95's Avatar
I have polished my front valve cover, a/c lines, power steering lines, Timing chain cover, firewall brake lines and The mevi. They arent the best job ive done but it does take a lot of time. All pics are in my cardomain.
Old Feb 26, 2005 | 05:11 PM
s0ber's Avatar
theres my progress so far once again... 90% complete.
Old Feb 26, 2005 | 05:45 PM
s0ber's Avatar
Old Feb 26, 2005 | 05:49 PM
gtr_rider's Avatar
192.168.1.1
missed a spot
Old Feb 26, 2005 | 05:55 PM
s0ber's Avatar
you missed a spot...
:looks at ur entire engine bay:
Old Feb 26, 2005 | 06:01 PM
gtr_rider's Avatar
192.168.1.1
who did it?
Old Feb 26, 2005 | 06:02 PM
s0ber's Avatar
You... Hasnt been washed in almost a year
!!@)(#*!@#(*!@)(# MAXIMA TRATIOR.. go play with ur 240..
