anyone else having suspension noises
Old Apr 29, 2002 | 08:36 PM
max2nermd's Avatar
seems like alot of people with 4th generation maxima's are having banging noises from their rear suspension setups. Does anyone not have this problem and what did you do and what did we do wrong????????????? I'm really stuck on this subject seems I tried everything ex. trimming bump stops, spiral wrap on the coils,
Is it hopeless to say we won't have a quiet suspension someday????????? the noise is driving me nutzzzzzzzzzz!!!!!!!!!!!!!
Old Apr 29, 2002 | 09:47 PM
rmb's Avatar
rmb
Re: anyone else having suspension noises
I've got H&R's + AGX's that I just did about 3k ago.... No noise at all. I didn't wrap anything special in the rear either. No PVC hose or wire wrap at all.
Make sure the springs are seated correctly in the bottom seat. Make sure the original rubber-cover thingy is on the bottom coils and between the spring and the seat.
Make sure that red paper/plastic gasket is between the top of the strut assembly and the vehicle.
Make sure the center strut-rod nut is tight and there are no cracks in the rubber pieces that get compressed when you tighten that nut all the way.
As a last resort replace all rubber pieces in the rear strut assembly(two rod-bushings, spring seat)....
Have you done any of this? What spring/strut? Describe the noise and when exactly you get it. Are you sure its from the rear?
-RMB
Old Apr 30, 2002 | 06:16 AM
max2nermd's Avatar
Re: Re: anyone else having suspension noises
-RMB
well it's like a banging sound whenever i go over bumps and potholes
I run agx with eibach
I haven't replaced the rubber pieces because I don't really think that is the reason for all the noise
Old Apr 30, 2002 | 09:23 AM
JAY25's Avatar
Re: Re: Re: anyone else having suspension noises
Once in a while if I go down this one street it has little dips on it my rear suspension will make this clak clak noise, is not loud but you can hear it as I am taking the curve at 35MPH, I have not heard it lately since I reversed my rear intrax springs tight coils on top for a perfect fit for the rear Koni perches.all the noise [/B][/QUOTE]
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
uttadms31
Sep 30, 2015 05:24 AM
