Thinking about painting cloth seats (opinions?)
Old Apr 30, 2002 | 06:36 PM
EN_Maxima's Avatar
I have a 1995 GXE w/ the charcoal colored cloth seats. I'm thinking about taking them out and spray painting them. I'm going to leave the center gray and then to the left and righ of the stitching black or vice a versa. Has anyone done this before or have an opinion this? Also, how hard is to remove and then reinstall the base, cloth, non-power seats? thanks.
-Ian
Old Apr 30, 2002 | 07:20 PM
FJC's Avatar
FJC
Re: Thinking about painting cloth seats (opinions?)
-Ian
Yeah, make sure to get enamel paint...
Is this a serious question???
If so, I wouldn't...
Old Apr 30, 2002 | 07:21 PM
ny96max's Avatar
you can dye the cloth, i dunno aboit painting
Old Apr 30, 2002 | 07:27 PM
clee130's Avatar
Probably not worth it in the long run. Cheaper to swap them out.
Old Apr 30, 2002 | 07:28 PM
Kashoggio's Avatar
its going to be hard to dye the seats with perfect lines , so you can make it two toned. Go for it lets see what happens
Old Apr 30, 2002 | 07:55 PM
-MaxPayne-'s Avatar
painting the seats? wouldn't that make it crunchy to sit on or something? Dying might work, but would not be worth the effort.
-Jon-
Old Apr 30, 2002 | 08:25 PM
ladeesman's Avatar
Indeed you can air brush them with a cloth designed paint. THis will make them slightly crunchy. Also you would need to heat set the color. It will still fade and will eventually rub off mostly, only leaving the remeinace of a color. If you air brush a dye you might have it. Don't subject your max to it though. Try it elsewhere 1st. Oh yeah and unless you know how to airbrush and are expereinced at it, have someone do it 4 you that is.
Old Apr 30, 2002 | 08:30 PM
ladymax20's Avatar
-Ian
I wouldn't spray it will probably give you a rash or something...yes it will fade...why don't you shop around professionally first
Old Apr 30, 2002 | 09:08 PM
Nealoc187's Avatar
SLOW
Hahaha spray painted seats, what will they come up with next.
Old Apr 30, 2002 | 09:12 PM
EN_Maxima's Avatar
Re: Re: Thinking about painting cloth seats (opinions?)
lol, wow pretty positive feedback! Well reason I thought it would work was because we were painting the interior of my friends trans am and he wanted to do his speaker coverings. Same cloth as the ones that are on your floors at home. It colored them good and the fabric was only a little stiff, not bad. I figured it would probally work with the seats. What I plan to do is cover the areas I don't want painted with newspaper and use masking tape around the edges.
I guess i'll just talk to some more people about it and see if I can find a paint specifically designed for painting cloth on the seats. I mean..... whats the worst that could happen
-Ian
MAXSE5SPD
Sep 17, 2022 04:00 AM
stevesmax
Dec 17, 2020 11:57 AM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
