Peeps with PaceSetter STS!!!!!
Old May 3, 2002 | 10:28 PM
190hpKiLLA's Avatar
Granny Driven
I got my STS and how the hell do you use it?
The white ball has to go onto the longest thread?
How do you get it there wont go any further then the short thread.
As I understood correctly the higher you place the ball the shorter the shifts will be?
What besides the ball should I greese? The instruction are written in greek Thank you.
Old May 4, 2002 | 12:25 AM
Mishmosh's Avatar
Re: Peeps with PaceSetter STS!!!!!
Dude,
You need to read the instructions! It's obvious from just looking at the thing and seeing pics of a shifter. It may be hard to push the ball past the elbow but it should go on the lower threads. Once there, positions it so that the ball just covers the top of the threads--that is the short throw position. Down low on the rod is the long throw position. And the ball is the only thing that needs lubed.
So get to it! You are sure to love it... Still can't believe how much fun factor the sts puts in!
Old May 4, 2002 | 12:44 AM
NYCe MaXiMa's Avatar
If you need help, let me know.. I'm sure it's not that hard
Here are the directions from Maximadriver.com... doesn't seem tOO hard if you have tools and patience..
http://www.seas.ucla.edu/~cheston/throw.html
Old May 4, 2002 | 01:34 AM
Kevin Wong's Avatar
I used a rubber mallet to pound the ball to passed the bend of the shifter. I don't think there is any other way.
Old May 4, 2002 | 05:13 AM
trinity000's Avatar
i just cut 1.75" off my real shifter and saved myself $70 i was to lazy to replace it... this was quicker and cheaper and works just as good with an aftermarket shiftknob
Old May 4, 2002 | 05:59 AM
190hpKiLLA's Avatar
Granny Driven
Its not the same! I have my shifter cut. The shifter is short but the throws are NOT. Thats why I bought the STS.
Old May 4, 2002 | 11:53 AM
trinity000's Avatar
i don't know my throws seem shorter but i haven't felt a STS so i don't know...
Old May 4, 2002 | 12:48 PM
MAXEJA's Avatar
cutting it is not the same as getting a sts. the sts makes throws about 30% shorter while cutting just changes the leverage. I know people that are happy either way.
Old May 4, 2002 | 06:21 PM
190hpKiLLA's Avatar
Granny Driven
Well i got the STS instaled but its really stiff. It got better later but then again became hard like rock
Old May 4, 2002 | 06:28 PM
CKNY's Avatar
change your mtf and give a it a week or two. it'll loosen up.
Old May 4, 2002 | 06:57 PM
xHypex's Avatar
It'll loosen up over time, but you definitely need to use quite a bit of grease to make sure it's smooth. Mine also seems a little different when the car is warm and cold I used to have Redline MT-90, but now I have the factory fluid again and I haven't really noticed a difference.
-hype
Old May 4, 2002 | 07:44 PM
190hpKiLLA's Avatar
Granny Driven
My MTF is MT-90 No need to change.
mclasser
22
Nov 12, 2020 01:58 PM
Wolvee
Aug 11, 2015 12:24 PM
TarHeelMax
Mar 27, 2001 08:28 PM
ebb
Dec 4, 2000 11:32 PM
