Can I........
Yes you can. SE ones work too. Make sure it matches the specs of your car. I.e. California of Federal. To tell it it it California spec, look at the front bank of the engine Valve Cover. If you see four harnesses in front of your engine its Cali spec. If there are only two, its Federal. Make sure that you and your donor car have the same spec.
thanx guys for the great info ill check them both out.... ill have him come by one day b4 he sells his car and ill drive it see if it works,
do either of u know what signs i should be looking for to see if the car responds to the ecu ? ie- top speed, ??
