Questions.........
Old May 5, 2002 | 12:14 AM
LegendLS
Questions.........
Hey all, first time on this. i dont own a maxima, my gf does. Questions I want to ask is:
when do you have to get the timing chain replaced? ever? she is 90+ K miles on her 95 maxima. Heard people say never but is that really the case?
Also weirdest thing happened this week, her antenna goes up when she turns off the radio and goes down when she turns it on.
Idea what it could be?
Also her rpms rarely work. Most of the time they dont, either stuck pass 8000 rpms or stuck on 3000. Sometimes when floored they work again momentarily.
could it be a bad cable?
thanks in advance
Old May 5, 2002 | 12:24 AM
LegendLS
The antenna goes up when the radio is on so the reception is greater than if it is down. It looks beat if the antenna is always up, so thats why the wonderful Maximas have an antenna that is hidden when the radio is not on
huh? the problem is the opposite...read the post again
Old May 5, 2002 | 08:05 AM
mzmtg's Avatar
Minister of Silly Walks
The timing chain is designed to have a life of over 200000 miles, so dont worry about that one.
As for the antenna, that sounds like a wiring problem, but you'd just have to take stuff apart to find it.
The instrument cluster is all electronic, so check all the RPM signal wires between the engine, ECU and tach.
Get a Haynes manual.
DTR Maxima
Mar 7, 2005 10:57 AM
