What in engine would require cleaning for revival of performance
Old May 5, 2002 | 01:01 PM
madmax97's Avatar
What do you need to clean or change under the hood that could cause lacking perfomance ? thanks
Old May 5, 2002 | 03:27 PM
Paradoxish's Avatar
Re: What in engine would require cleaning for revival of performance
Let's see..
Clean your throttlebody, change your fuel filter, replace your spark plugs..
I'm sure I'm missing a thing or two?
Old May 5, 2002 | 03:49 PM
sureal00's Avatar
transmission fluid ,air filter
Old May 5, 2002 | 06:51 PM
sleeper's Avatar
revival
engine oil and filter, ah duh
Old May 5, 2002 | 07:41 PM
Nismo87SE's Avatar
Throttle body and intake manifold mostly.
Old May 5, 2002 | 07:45 PM
SLC I30t's Avatar
you might get something by getting the the upper intake and injectors cleaned as well.
Old May 5, 2002 | 09:29 PM
Paradoxish's Avatar
Something like this should be probably be in the FAQ...
Old May 5, 2002 | 09:34 PM
phatmax95's Avatar
If just cleaning the throttle body helps so dang much, then it must help to clean the intake manifolds out... Aynbody done this. or know anything bout it??
Old May 6, 2002 | 07:45 AM
SLC I30t's Avatar
I took mine in to a shop to have my upper intake and injectors cleaned.. they spray some misti stuff into your intake that eats up the carbon... I don't think that your upper intake gets too cleaned by the TB cleaning, I would imagine your throttle body gets to clean unless you take it off and clean it by hand.
Old May 6, 2002 | 08:04 AM
meccanoble's Avatar
Sports Button FTW
i really need to clean mine but never find the time....argh, wait till school is done...2 weeks left!!
Matt93SE
May 24, 2019 02:58 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
