does the maxima body really flex that much as to need a fstb?
I don't get how the fstb helps that much, I mean its not connecting suspension component just structural elements. Unless of course the body/frame flexes that much around turns...
Re: i have one
Do the ones on e-bay for $20 work as well as the more expensive brand names? Why are they so cheap?
Originally posted by Justin95SE
you can tell its onthere, great mod for the buck, check ebay for them, they are like 20 bucks. i highly reccommend one.
Re: Re: i have one
Get the more expensive ones if you like the way they look, get the ones off of Ebay if all you care about is the benefit you'll get. You should get the same improvement from any FSTB you buy...
Originally posted by DrivinDaMax98
It sure does work though, im just wonderin why.
Here we go courtesy of Albertt.
http://e30m3performance.com/myths/St...bar_theory.htm
Originally referenced from front Strut bar what exactly does it do?
I thought the FSTB helped a lot in terms of wheel hop since the front suspension is tied together.
Could just be me
-hype
Could just be me
-hype
I have one and it seems like I can take turn at higher speeds. I haven't install my spring and shocks yet and I can notice the difference already. Its a good mod, they're cheap I got a good looking for $50.
Yes, it does and yes it helps a good deal.. A Strut bar is a common modification for most cars.. this is almost like an Intake or an exhaust..
The strut towers "move" up and down, when you go over a bump, the car hops, your strut towers contract as the mass of the car kind of drops on top of them.. When you are driving spirited and take a turn, the mass of the car shifts to the side, so on a hard right turn, the left side of the car would take lean down from the mass shifting over to it.. However, with a strut tower, the left tower is held to the right one..
At least thats how I understand it..
It's like if you stand on one leg, you can be pushed down a lot easier then if you were standing on two legs.. same principle
FSTB = cheap, worthy investment.
Re: does the maxima body really flex that much as to need a fstb?
In any case they really work well on Max's... The RSTB (rear-stabilizer-bar, not RSB) is useless on the Max IMO since the rear is already stiff enough.
-RMB
The FSTB does not affect up and down movement of your front suspension. It only affects the side movements.
Picture this: you take a hard left turn. What's your suspension doing? Your right front strut is taking most of the brute force of the turn. Because of this, and the fact that the body is not completely rigid, the right front strut will bend a little outwards, to the right, changing your camber(or toe?). Now, without the FSTB, the left front strut, which is not really feeling anything in this hard left turn, doens't flex much. So, the left strut stays the same, but the right struts bends out a little. That's what causes your steering to feel a little strange. With the FSTB, the movement of the right strut will also move the left strut. Result, they move together, relative camber (or toe) stays the same, and your steering feel will be more linear.
HTH
DW
HTH
DW
HTH
DW
HTH
DW
sort of... but the the fstb actually helps to reduce the camber change by simply stiffening the front end across the strut towers. It's intention is not to transfer camber deflection to the other corner but just to add rigidity.
-RMB
imma solve this one
yes get the FSTB you will love it. I do to the point where i wonder why nissan just didnt install it.. what it does? it works..How does it work...call your high school or college physics teacher... or you can call the manufacturers cause i see a million different answers .
Lakersallday24
Nov 7, 2024 07:31 PM
doobadoo
Aug 15, 2015 06:43 PM
jholley
Aug 11, 2015 09:38 AM
