Just ordered pulleys from custommax/unorthodox
Old May 6, 2002 | 11:05 AM
ChrisG's Avatar
Are these easy to install?
Old May 6, 2002 | 11:16 AM
Finality's Avatar
http://www.greghome.com/Greg's%20Gar...e%20Pulley.htm
Old May 6, 2002 | 01:01 PM
SuDZ's Avatar
They are both very easy to install and a huge pain in the butt to install. When I did mine it was easy right after you get the center bolt off. It took a while and needed an air pump set to 175 pounds to get mine off. After that not so bad but breaking that bolt took some time. Once you get that done it is pretty easy from there.
SuDZ
Old May 6, 2002 | 03:46 PM
dashingMax's Avatar
UDP Install
Just get a Haynes & Chilton's manual.
They both have detailed, step-by-step instructions.
Also, have some air tools readily available. I tend to use the electric impact wrench from Craftsman.
It would also be a good idea to get a OEM bolt from the dealer...just in case you break yours.
Good Luck
Old May 6, 2002 | 10:48 PM
iregula's Avatar
does that part work?
Old May 7, 2002 | 06:23 AM
dashingMax's Avatar
UDP is a long debated issue. Several magazines articles have shown that the UDP will give you 4-5 wheel hp at lower rpms. This of course has been on BMW's & VW's...not a Maxima yet.
Please, let's not get into the UDP debate...
To each their own...
Old May 7, 2002 | 06:46 AM
SuDZ's Avatar
Get a good breaker bar too with the 19mm socket because eve with the air tools that thing took some power to get off. Start spraying now with some rust remover stuff to try to lube it up a bit to give you a head start.
SuDZ
Old May 7, 2002 | 07:24 AM
dashingMax's Avatar
SuDZ
Agree. WD-40 works quite well!
I believe you'll need a 19mm deep socket
Old May 7, 2002 | 07:37 AM
sinewave's Avatar
Try this technique; it works.
http://forums.maxima.org/showthread....pulley+starter
Old May 7, 2002 | 08:54 AM
Jime's Avatar
I did mine using the starter method too and it works fine. Took 3 tries before it came off. If you have an auto and don't have an impact wrench its the only way I know of.
Old May 8, 2002 | 08:25 AM
ChrisG's Avatar
SuDZ
Did you ever have any problems with your accesories or anything like that after you installed it.
Old May 8, 2002 | 09:25 AM
sinewave's Avatar
I've had mine for almost 3 years now and have not had any problems with reduced charging, A/C, or power steering boost. The only problem I had was that I had to adjust the belts several times over the course of a few weeks.
It's not a crime if you don't get caught
"Character" is doing the right thing when no one is looking.
JakeOfAllTrades
Oct 5, 2015 10:40 AM
bigfrank
Oct 1, 2015 12:51 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Pied
Sep 26, 2015 03:29 PM
