Can I get an ECU code if my Check Engine Light isn't lit?
My car is seriously ******* it, and the symptoms lead me to any of several sensors. But I'm not getting a CEL! Anyone know whether I'd get a "No Fault" reading if I pull codes without my CEL on?
Originally posted by clee130
My guess is that you'll get a "no-fault" code since sensors need to trip the ECU in order to get a code.
You could always try it, but you'll probably get a "no-fault" code.
http://forums.maxima.org/showthread....t=Knock+sensor
Chances are you won't get much help around here on ECU codes
-hype
Originally posted by jayanth
Try checking the resistances of the front & rear O2 sensors and the KS.Check to see if the CEL bulb is not blown out.
Thanks for your help, guys. If anyone has more info I'm all ears.
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
