low idle after changing fuel filter
Old May 12, 2002 | 05:17 PM
NyC97Max's Avatar
hey i changed my fuel filter last week, and ever since i put a new one in, my idle has been rather low, lie around 500 while in drive, and 600 in neutral..im an auto by the way..my car shakes a bit when im at a light...it was a brand new nissan OEM filter, and i changed it perfectly, and i havent seen any leaks...i took off the airbox(stock) and the other tube between the airbox and throttle body, so that way i can reach the filter easier..and i put it back the same way i always have and i dont think i messed up putting the airbox back together...so has this ever happened to anyone?? any suggestions
Old May 12, 2002 | 06:01 PM
kvzeyde's Avatar
idle problem
Don't know if it is related but I had a low idle problem after cleaning my throttle body. Then thanks to a thread about "high idle" I cleaned my Idle Air Control valve. Now my idle is perfect. Do a search for the "high idle" thread. There are great directions there for cleaning the IAC valve which will probably solve your problem. You may need to clean your throttle body as well (if you have not done so recently).
Old May 13, 2002 | 08:15 PM
NyC97Max's Avatar
nope i cleaned my throttle body less than a 1000 miles ago, so im not sure wut it may be
Old May 15, 2002 | 11:04 AM
kvzeyde's Avatar
check thread
Did you check this thread?
http://forums.maxima.org/showthread....t=idle+problem
Old May 15, 2002 | 12:53 PM
jayanth's Avatar
Check if you have installed the filter in the right direction!!!
Old May 15, 2002 | 12:56 PM
deezo's Avatar
Good point! I've switched mine twice and had no problems afterward.
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
sdotcarter
Sep 2, 2015 09:53 PM
