VI hard to install?
Looks relatively easy. I am hoping to get one as well. I've seen one in person and it looks like a really simple install. Here's a link to IanS install intstructions. http://www.cyberhub.net/intake/
Re: VI hard to install?
Originally posted by 97MaximaGLE
I want to order the VI for my 97 auto GLE and I was wondering how hard it would be to install.
Re: ??
Can you run it withou the switch for awhile or how does that work?
-John
Re: Re: ??
Since your VI is always on, has lo end TQ suffered at all compared to stock?? Just curious.
DW
DW
Originally posted by Mr Cranman
Yeah if you don't have the switch it will drive like a normal Maxima or you can tie the VI open at the actuator to feel the boost in the upper RPMs. But there is no problems driving the car without the RPM switch. So, your car is drivable in about 2-3 hours after the install, so if you don't have time for the RPM switch you can put it off for next weekend and still drive the car around. Hope that made sense.
-John
-John
All you need are ordinary hand tools and a torque wrench. 1997 on up maximas have the evap and other emission control items mounted on top of the intake manifold where 1995 and 1996 maximas do not. To be safe I labeled all the parts with strips of tape to keep track of that rat's nest on top of the intake manifold. Removing and installing the two mounting bolts and the coolant hoses on the back of the manifold are the most time consuming steps due to limited work space and not being able to see what you are doing.
I had to fashion a small bracket which I made from a flat strap of steel to mount the evap to. There are no threaded studs on the VI to fit the evap onto which are present on the OE manifold.
The vacuum system is a cupcake to set up. Just "T" off of the evap hose and make the appropriate connections for the vacuum reservoir and solenoid.
Wiring the RPM switch off one of the coils is the easiest way to install it. I'm a masochist myself and decided to wire the RPM switch inside the passenger compartment.
Re: Re: Re: ??
DW
DW
-John
Re: Re: Re: Re: ??
Yes the low end hasn't suffered much but the mid-range like 3500-5000 has definitely suffered and I have notice a big change there. That is why I need the RPM switch. But, I do have to say I love the high end pull. It rocks
-John
-John
Re: Re: Re: Re: Re: ??
Originally posted by speedtrip
Hopefully with a more free flowing exhaust than what I have on my max you won't suffer the same mid range hp/torque loss that I did even with the VI completely installed.
Re: Re: Re: Re: Re: Re: ??
Originally posted by Toolrocks
Don't you have a ypipe? If you do, what else do you think would be better to add? Btw, I'd like to see the dyno of one of these w/ the factory intake.
Re: Re: Re: Re: Re: Re: Re: ??
yes I have a y-pipe but after that I am stock. Mr. Cranman has a y-pipe, ahem "free flowing" cat, and a cat-back exhaust. I would think his entire exhaust systems flows more than mine.
Re: Re: Re: Re: Re: Re: Re: Re: ??
I guess we won't know until we see his dyno. It seems like there are so many possible variables. Exhaust restrictions, exhaust velocity, altitudes, etc. It will be interesting to see. Can't wait. It's been my understanding that exhausts don't do too much for our cars.
-John
Update to everything:
i did 8 Dyno runs between 3500 and 6000 RPMs.
5000 was perfect. If you go any lower, then theres not enough pressure buildup and you drop hp and tq and never fully recover it by redline.
If you go too high, you don't get the full effect.
Also, I have worked out a solution for my PayPal problems, and it goes like this:
I'm tkaing 50% up front. In 2 motnhs, when the VI's arrive, I will take the other 50%. if you don't have your other 50% by then, then I will simply sell it to someone else and give you your money back.
I can take checks or money orders or wire transfers. See hte "Varible intake GD" thread in the GD Forum for informaiton on why i can't and now won't use PayPal.
They are a shaaaaady company.
Hopefully this 50% thing will help people with cash flow problems and give them time to save up the rest. Total price is $560 to your door.
E-Mail me at cyberoptik@cablespeed.com with questions.
Thanks,
IanS
Thanks,
IanS
MaxLife17
Jun 27, 2019 01:37 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
