altima bites the dust
Old May 14, 2002 | 08:30 AM
Jamsan's Avatar
well on the way home from school, some stupid altima was riding my *** (i was already doing like 75, speed limit = 55)...and i was like oh ya, so i took off, and he tried to keep up, but i ended up doing 120 the whole way home (governor limited )...but then i turned overdrive off, and it revved higher, and i actually climbed to about 123 before it stopped again....stupiud ECU.....but ya, altima ended up way many cars behind....atleast 25
Old May 14, 2002 | 08:57 AM
amb4081's Avatar
Re: altima bites the dust
How is it that your ECU has a speed limiter (governor) with an SE? An SE ECU should not have a speed governor.
Old May 14, 2002 | 10:09 AM
Jamsan's Avatar
i dunno but i cant go faster than 117 if its not a hill
Old May 14, 2002 | 10:20 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
25....
Old May 14, 2002 | 11:57 AM
dwapenyi's Avatar
When's the last time you changed your feul filter? I had top speed problems when I 1st got my car. replaced my feul filter and my car went all the way.
DW
Old May 14, 2002 | 05:16 PM
Jamsan's Avatar
ok well how do i change my fuel filter....
Old May 14, 2002 | 07:14 PM
93_MaxSpeedMark's Avatar
For what it's worth, I've noticed the exact same thing in my 96 SE. Seems very much like a governor, I think if it were the fuel filter, it would just slow down the acceleration in the top end. And my top end is excellent, the car pulls steady from 80 to 115, then it just kinda dies. At 120, it sounds like a rev limiter at about 4000 - 4500 RPMs.
Old May 14, 2002 | 07:47 PM
Jamsan's Avatar
ya mine dies around 2k rpms
Old May 14, 2002 | 09:18 PM
spiff56747's Avatar
hey jamsan, I LOVE your grille, it looks like the Kamei grilles they have for VWs. Did you make it yourself? And out of what? Got any closeup pics? Thanks
Old May 14, 2002 | 09:59 PM
KSU1998's Avatar
spiff is right, that grill looks good....
The trick VW's and Audi's have a similar look
I second the pics and info..
thanks in advance,
Dale
Old May 14, 2002 | 10:09 PM
iansw's Avatar
I have a 97 GXE and I've gotten it up to 130...couldn't go any faster only because I got scared...
I thought I had a governor, but I guess I don't!
What makes a car have a governor? I thought it was all GXE's, but apparently not....
IanS
Old May 15, 2002 | 04:45 AM
nismo2020's Avatar
Needs non-Maxima Friends
IanS
do you have any options with your gxe?
Old May 15, 2002 | 05:54 AM
Jamsan's Avatar
my friend photoshopped the grill when he made my sig...do you' still love me ?
Old May 15, 2002 | 06:05 AM
dwapenyi's Avatar
It's easy .. . well, depends. Do you have ABS?? If you have ABS, it can be quite hard, if you don't, then it's easy. ABS makes it hard b/c all the ABS lines are get in the way.
Here's the instructions;
http://web2.airmail.net/scutchen/max...lter/index.htm
DW
Old May 15, 2002 | 08:05 AM
Jamsan's Avatar
do i have to jack my car into the air to do this?
Old May 15, 2002 | 08:36 AM
dwapenyi's Avatar
If you have ABS, maybe.
DW
Old May 15, 2002 | 09:59 AM
iansw's Avatar
Yeah, C$C and Power Driver's Seat.
I was told by someone on this board that ALL GXE's had a governor, which is why I was totally surprised when I hit 120....125...130...
IanS
Old May 15, 2002 | 11:38 AM
paul-e's Avatar
i have a 96 se and get past 123..
Old May 15, 2002 | 12:27 PM
Jamsan's Avatar
ok so where can i get this fuel filter, and how much does it cost?
Old May 15, 2002 | 12:31 PM
iansw's Avatar
Get a 300Z Filter. Look in the Max Maintenance FAQ for the part number.
While it doesn't improve performance, it DOES last twice as long because of more surface area....
Courtesy Nissan sells them.
IanS
Old May 15, 2002 | 12:34 PM
Jamsan's Avatar
eh i was hoping, maybe they have something along the lines of a regular standard issue fuel filter at maybe a pep boys or auto zone?
Old May 15, 2002 | 12:44 PM
iansw's Avatar
They have the 300Z filter at pep Boys and Auto Zone.
Old May 15, 2002 | 12:46 PM
Jamsan's Avatar
how much does it cost, and can u like go to autozone.com for me and look for the part no. ? wvu
Old May 15, 2002 | 12:52 PM
iansw's Avatar
I did a search and found it right away.
16400-N7600JP
That's the last time I'm letting someone be lazy and not making them search themselves.
I always seem to say that.....
IanS
Old May 15, 2002 | 12:53 PM
deezo's Avatar
DW
Its easy if you have small arms. I had scrapes and bruises all over my forearms after changing mine out.
Old May 15, 2002 | 12:58 PM
Jamsan's Avatar
coudlnt find it...maybe a link?
Old May 15, 2002 | 01:11 PM
hakk97se's Avatar
IanS
Ian, FYI, GXE's with the C&C package don't have the limiter. That explains you.
I can't however, explain why two people in this thread claim to have SE's with limiters. Either someone tricked you into thinking you had an SE when you bought the car, or there is some other problem that is not the ECU. I suggest checking your VIN numbers using the decoder to make sure you have an SE...
Old May 15, 2002 | 01:12 PM
Jamsan's Avatar
ya i have done that already long ago, and its an SE....i hope its the fuel filter problem...because if it was limiter, it wouldnt go to 123 going up hill (when i turned OD off it went that fast)
Old May 15, 2002 | 04:11 PM
DiscoGsus's Avatar
Only a few 95-96 GXE's have governors, it makes me glad I gave the GXE to my sister and bought the 99SE.
It is also in the FAQ
Old May 15, 2002 | 05:33 PM
Paradoxish's Avatar
DW
I have ABS and I managed to change my fuel filter without jacking the car up. It's kind of cramped and hard, but doable.
Old May 15, 2002 | 06:06 PM
iansw's Avatar
It may be slightly different, but I was able to change ebmorgan's I30 with ABS without jacking up the car also.
IanS
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Dec 12, 2015 09:39 AM
trsandrew
Oct 25, 2015 02:47 PM
londonflu
Sep 19, 2015 02:33 PM
