96 Auto: Hard shift into second
I have a 96 Automatic. When shifting from 1st-2nd usually before the car has a chance to warm up, it shifts real hard. Occasionally, it will even shift back to first, like it wasn't really ready to shift into second in the first place. Could this be caused by the low-end lack of power due to my JWT Pop Charger, or is it more transmission related.
I can't tell because it seems like the engine is forcing a shift before the transmission is ready for it...
Am I making any sense? Anyone have any suggestions?
Thanks in advance for your reply.
You are making sense. Now a couple of questions.
1) How hard are you stepping on the gas when this happens?
2) What RPM's is the tranny shifting at.
3) When was the last time the fluid was changed or the level checked for that matter?
4) Is your POP Charger really dirty?
Check the dropping resistor that is located on driver's side front strut tower. It is a horizontally mounted silver rectangle, about 3 inches long, that has a 2-wire connector on one end.
When you unplug a properly working resistor, the transmission will shift very hard. If you notice no change shift firmness when you unplug it, you either need to replace the resistor or check the wiring harness.
Check your throttle position sensor
My '96 GXE was doing the same thing, so I took it to the dealer. I brought some printouts from this web site (do a search for "shift shock" and you'll see a bunch of info about this problem), and it turned out to be the first thing on the diagnostic list: misadjusted throttle position sensor. I've noticed that the cold shifting is still a little harsh, but it's much better after the car's warmed up. Adjusting the TPS definitely made a difference.
There's actually a web site that I've seen referenced here that has detailed instructions on how to test/adjust your TPS using only a multimeter and a screwdriver (do a search to find it). You might want to try that if you want to save yourself the hassle and cost of going to the dealer.
Re: Check your throttle position sensor
Where is this throttle posotion sensor, i have the same problem with my 95 max with 114,000 miles on it and this might be the trick. Please someone save me max and tell me where this dam thing is. My car has a lot of trouble shifting sometimes, and whatever you do, do not screw around with that shift resistor!!!!is will perminatly mess up your tranny!! please help me where is it located.
Re: Re: Check your throttle position sensor
http://www.vbxmaxima.8m.com/tps.html
Normal to Hard
Probably 2500 RPM
A month ago
Normal to Hard
Probably 2500 RPM
A month ago
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
fx4five
10-01-2015 04:58 AM
