Valve Clearance in this generation
Originally posted by wczimmerman
I thought I read somewhere that the 4th gen Max has solid lifters-does that mean that I need to have the valve clearance adjusted at some point? I thought that was the whole point behind hydraulic lifters...
The bad news.
Changing valve clearance requires special tools. This is not a simple matter of turning an adjustment screw. It requires removal of a precision-machined disk-shaped shim, and replacing it with another shim of a different thickness. You buy ($$$) the shims from the dealer.
The good news.
You'll probably never have to do this. It is necessary after major engine repair such as grinding the valves or replacing a camshaft. The factory maintenance schedule does not call for periodic valve adjustment. All it says on the subject is in a footnote which says "If valve noise increases, inspect valve clearance."
TKHanson
Nov 24, 2018 01:39 AM
mkaresh
Mar 12, 2018 06:48 PM
rbaksi
Mar 25, 2016 06:10 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
