Throttle Position Sensornot Knock Sensor
Old May 18, 2002 | 11:35 AM
blakkrob's Avatar
Throttle Position Sensor not Knock Sensor!
I just realized today that my TPS is bad not my KS! WOOO! Just saved my self a lot of money and the hassle of trying to replace a knock sensor. So you guys that think you have a bad knocksensor should make sure that is exactly whats wrong. Has anyone ever changed there TPS? Is it hard?
Old May 18, 2002 | 01:04 PM
Nismo87SE's Avatar
It has 2 bolts and 1 clip plus its on the throttle body. Should take less than 1 hour to replace.
Old May 18, 2002 | 02:35 PM
ripper7's Avatar
How did you figure out your TPS was bad? I've been trying to do the test based on the Haynes manual but am not excatly sure if TPS is bad or not. FYI the 2 screws are small and hard to remove, if you can't remove it initial spray some liquid wrench, and let it sit overnight.
It work for me.
Old May 18, 2002 | 02:51 PM
blakkrob's Avatar
I got the CEL code0403
Old May 18, 2002 | 03:24 PM
tekmode's Avatar
if u wanna know if its bad or not take it out and take it to autozone, they will test alot of **** for free. i know because i work there. and gawdaym a KS for a maxima is 250 buks
Old May 18, 2002 | 03:28 PM
1MAX2NV's Avatar
It's easier with the TB off the car to get the TPS off. Just a warning, those screws are on very tight. Normal screwdriver won't able to break them loose. You will need an impact screwdriver. I could take some pictures if you want. I have a spare TB.
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
ac max 92
Sep 17, 2015 07:35 AM
