Knot sensor problem
Old May 21, 2002 | 04:55 PM
cyrus2k1nyc's Avatar
Knot sensor problem
What the hell is a Knot Sensor? I'm getting a Knot sensor problem for my car inspection. Anyone ever had this problem? Anyone even know about this problem? ******* KNOT SENSOR.
Old May 21, 2002 | 05:01 PM
Stillen_I30's Avatar
a search would explain it all...try it out
Old May 21, 2002 | 05:13 PM
mzmtg's Avatar
Minister of Silly Walks
Are you sure you dont mean knock sensor?
Old May 21, 2002 | 05:22 PM
Toolrocks's Avatar
I think it's my shoe strings tripping the knot sensor in my car.
The knock sensor is used to vary the ignition timing in an effort to prevent engine knock. Replacing it may make the car seem more powerful or do nothing. IF you repeatedly get the code then replace it. Most shop manuals tell you to remove the intake manifold but myself, and several other people have been able to do it w/o removing the intake. It is easier on a 95 but can be removed on all 4th gens w/o removing the intake. The knock sensor is located in the valley between the two banks of cylinders. It's in the middle of no where. I'd recommend you get a Haynes manual, and try the install yourself. Also, do a search on "knock sensor". Good luck.
Old May 21, 2002 | 07:58 PM
rmb's Avatar
rmb
Re: Knot sensor problem
That's Knot Censor. A knot censor is activated when an unsafe knot is being used. (i.e. two overhand knots to join two ropes rather than a proper double fisherman's knot)
Check your ropes and/or jumper cables.
-RMB
Old May 22, 2002 | 12:39 AM
again, i would highly suggest doing a search...i just remembered that a few days ago, someone had produced a nice write-up complete with pictures to help find the part. its only from a few days ago, so dont look too far back...
Old May 22, 2002 | 06:08 AM
njmaxseltd's Avatar
This may help the guy out, I did a search on Knot Sensor and came up with this thread.
http://forums.maxima.org/showthread....ht=knot+sensor
Old May 22, 2002 | 04:00 PM
HAHAHAHAH
Old May 22, 2002 | 08:23 PM
PejMax97SE's Avatar
Hahahaha KNOT KNOT, whos there.
Old May 22, 2002 | 11:22 PM
apocnmbr1
Originally posted by Stillen_I30
HAHAHAHAH
I think whats it's telling you that it's knot the sensor, but could be something else???? just a thought..hehe
Old May 30, 2002 | 03:23 PM
NUGE's Avatar
I am not getting an error message for the knock sensor. But when my car is shifting ( Auto trand ) between gears, I hear pinging for about 1 second. Especially if the A/C is on. I alos hear it when going up a hill. Does this mean I have to change my knock sensor?
Old May 30, 2002 | 03:46 PM
papasmurf's Avatar
Honda Convert!
Go here
Bruce
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
